Took a PIC With The Champions
Old Mar 12, 2007 | 01:10 PM
PCJR's Avatar
PCJR is a splendid one to beholdPCJR is a splendid one to beholdPCJR is a splendid one to beholdPCJR is a splendid one to beholdPCJR is a splendid one to beholdPCJR is a splendid one to beholdPCJR is a splendid one to behold
Originally Posted by ari
I wanted these rims on a TT before I even owned a one.
I'm going to try a 15mm spacer in the next few weeks. I'm almost positive I can get away it. I'll let you know how it goes.
Ari,
I used 10mm on the front and 7mm on the rear which landed the rims exactly like the factory GT2 offset. Make sure you get longer, polished bolts.
Old Mar 12, 2007 | 04:24 PM
SmoothCab's Avatar
SmoothCab Is a GOD !SmoothCab Is a GOD !SmoothCab Is a GOD !SmoothCab Is a GOD !SmoothCab Is a GOD !SmoothCab Is a GOD !SmoothCab Is a GOD !SmoothCab Is a GOD !SmoothCab Is a GOD !SmoothCab Is a GOD !SmoothCab Is a GOD !
Ari, they look very good and agressive... Sure cleans the machine up nicely... Good call!!!
Old Mar 13, 2007 | 02:14 AM
Turbo Fanatic's Avatar
Not sure exactly. maybe about 1.5" lower than stock? I measured the height from the ground to the highest part of the whell arch: 25 3/4" front, 26" Rear. Hope this helps.
This height is a great compromise between ride height and handling IMO. The car doesn't bottom out anymore and soaks up bumps very nicely making for good handling. Hitting the bump stops in mid corner can cause strange and unpredictable (sometimes dangerous) handling behavior whenyou lower much below what I have. I was also scraping the lip a lot coming into and out of driveways even when using the angled approach trick.
Pss9s have a magical way of softening the street ride while stiffening up the handling when set up properly due to the two-spring setup. Never tried Motons, etc. But I am uber happy with this setup as my car is a 99% street car.
If you want to go REALLY low, JICs and other brands allow you to lower the shock body which will let you get lower and still maintain acceptable wheel travel.
BTW I have FVD spec PSS9s which I believe use a slightly stiffer main spring.
My next mod will be H&R rear sways set at the medium stiffness setting. It's a pretty inexpensive mod that other feel is very worthwhile.
Originally Posted by Kevinw23
Those wheels look great. I am thinking of going with the PSS9's as well. How much lower is your ride height from the stock height?
Old Mar 13, 2007 | 02:15 AM
AutoTalent's Avatar
AutoTalent is just really niceAutoTalent is just really niceAutoTalent is just really niceAutoTalent is just really niceAutoTalent is just really nice
Looks very good, even better in person
Old Mar 13, 2007 | 07:55 AM
BMWDEMON's Avatar
BMWDEMON is a jewel in the roughBMWDEMON is a jewel in the roughBMWDEMON is a jewel in the rough
Ari, nice pick-up...if I ever get some "extra" wheels the are the ones I would get...
<M
Old Mar 13, 2007 | 12:02 PM
TKDalumni's Avatar
TKDalumni is just really niceTKDalumni is just really niceTKDalumni is just really niceTKDalumni is just really nice
Awesome! They look even better in person.
DLF
Cayenne 955/957
10
Feb 28, 2022 11:49 PM
goto35
Mar 8, 2020 07:41 PM
dan_189
Sep 14, 2015 01:03 AM
VEGAS9ELEVEN
Sep 9, 2015 11:13 AM
