wheel dimensions and offset: what do you have?
Old Mar 15, 2007 | 09:31 PM
willcoxmd's Avatar
willcoxmd is infamous around these partswillcoxmd is infamous around these parts
Hey guys,
I still need some help with my HRE 840R's. The front wheel dimensions are:
19 x 8.5 with 34mm offset. tires are 19 x 235 x 35
The rear wheels are 19 x 11.5 with 31 mm offset. tires are 19 x 315 x 25
What are most of you running?
Old Mar 16, 2007 | 04:05 AM
Kaizu's Avatar
Kaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud of
8.5x18" ET40 and 11x18" ET25. 225/40 and 295/30 tires and no problems with a low suspension (of course not with these tire sizes...)
The tires are PS2 for street and Cups for track.
If you have only a small problem with rubbing, a different alignment should help with those blingbling-wheels
Old Mar 19, 2007 | 04:09 AM
Turbo Fanatic's Avatar
Check out this thread: https://www.6speedonline.com/forums/...ad.php?t=77005
Mine is 19x8 46mm front.
and 19x11.5 44mm in the rear. You are running the same size rears with a 31mm offest. the 15mm spacers I tried looked very iffy in the rear even if I was to roll the fenders. Did you roll your rear fenders?
Does this mean that I can run a 13mm (doesn't exist) spacer in the rear an not rub? ...or is the offest divided by two to calculate at 6.5mm (they make 5 and 7mm spacers).
Old Mar 19, 2007 | 07:08 AM
GrettW's Avatar
GrettW is infamous around these parts
your offset is too low in the front, your wheel is completely flush with the fender isnt it?
Zero911
Aug 24, 2015 06:51 PM
Mar48
Aug 24, 2015 01:13 PM
ModBargains
Aug 20, 2015 12:28 PM
