Compression check - help me understand the results pls
Old Mar 17, 2007 | 10:01 AM
pvanosta's Avatar
pvanosta is just really nicepvanosta is just really nicepvanosta is just really nicepvanosta is just really nicepvanosta is just really nice
I just had a full PPI done on an '01 996 TT Tip.
This included a compression check.
The numbers on the fax I received, look like this:
1 190
2 189
3 190
4 191
5 190
6 191
What do these numbers mean and are they good/bad/indifferent?
Thank you for your input.
Old Mar 17, 2007 | 10:10 AM
silver's Avatar
silver is a name known to allsilver is a name known to allsilver is a name known to allsilver is a name known to allsilver is a name known to allsilver is a name known to all
These are numbers showing PSI in each cylinder and what you want is them to be all virtually the same +/- 5%. I don't know what the PSI should be but the closeness of the numbers is a very good thing. Equal is always better even if the compression is down a bit. Sounds good to me so far. That seems about what a 9.6 compression engine should be showing.
Old Mar 17, 2007 | 10:23 AM
pvanosta's Avatar
Thank you for clarifying that.
Patrick
Old Mar 17, 2007 | 10:36 AM
Divexxtreme's Avatar
Those numbers look great.
Old Mar 17, 2007 | 10:49 AM
Al Norton's Avatar
Al Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud of
I don't think a P dealership does this kind of test, but a much more meaningful thing to do is a cylinder leak-down test.
The compression testing is good for providing relative numbers from cylinder to cylinder, and yes, close numbers are good. There are some variables that are introduced in compression testing, such as condition of the battery, amount of crud and crust on piston domes, etc.
The leak-down test pressurizes each cylinder individually while locked at TDC and with a guage, helps to tell where the leakage is occurring, i.e. past the rings into the case, past a gasket into the coolant system, out the exhaust valve, or the intake valve, and so on. All cylinders will have some leakage but the percentage should be a low number for a healthy engine.
Old Mar 17, 2007 | 11:08 AM
Bill W's Avatar
Bill W is infamous around these parts
You can also alter the outcome of a compression test by adding a drop of oil in each cylinder, which would boost up bad numbers.
rzmnco
Cayenne 955/957
Oct 7, 2025 03:12 PM
su_maverick
Sep 8, 2015 11:12 AM
AdPock
Ferrari
Sep 1, 2015 10:13 PM
