Can anyone give me a little help on my front coilovers?
Old Apr 2, 2007 | 02:38 PM
cpu77's Avatar
cpu77 is infamous around these parts
Do I have to remove the front CV Axle? I know the tie rods need plit. I hate using a fork. Should I just try blunt drama Do I need to compress them or they should come out with plenty of room to spare!
Ralph
Old Apr 2, 2007 | 03:16 PM
dgreen78's Avatar
dgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond repute
DO NOT use a fork splitter. You dont want to tear the boot. Use this style:
http://www.kctools.com.au/images/TOO...E%20PULLER.jpg
I went down to my local Shucks and rented the tool for free.
Old Apr 2, 2007 | 03:20 PM
cpu77's Avatar
Damit DON Help a guy out After all your 78 and I am 77....
That helps. The backs were a sinch to do. Do I need to undo my front axles? Hub nut? DO I need to compress the front springs to get the strut out?
Old Apr 2, 2007 | 03:45 PM
dgreen78's Avatar
Ok 77, you need to remove the Big nut and remove the axles from the hub. It would be a good idea to compress the springs but you dont have to. I shot mine across the garage floor Let me know if you have anymore questions I just put my coilovers in not too long ago...
Old Apr 2, 2007 | 06:43 PM
cpu77's Avatar
Do I remove the axle from the front differential. I got my nut off and pounded the axle in but it won't go in very far. So my question is does the axle get completely removed? Does the tie rod need to be split?
Old Apr 2, 2007 | 07:43 PM
dgreen78's Avatar
No, you remove the whole assembly from the control arm. You dont remove the axle from the diff. Shoot me your email address I have pics of when I did it. I was going to make a DIY but I havent had the time.
Pictures are worth a thousand words....
Old Apr 2, 2007 | 09:16 PM
cpu77's Avatar
Don,
I got it all done just setting height now.
Thank you very much!
Ralph
Jul 29, 2019 11:13 AM
Enemy
Nov 10, 2015 08:01 AM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
gulf gt
Aug 27, 2015 10:27 AM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
