Serious stumbling on the gas.. Is this a MAF?
Old Apr 5, 2007 | 08:23 PM
Plugs.......
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Apr 5, 2007 | 08:29 PM
ruffinit's Avatar
ruffinit is a splendid one to beholdruffinit is a splendid one to beholdruffinit is a splendid one to beholdruffinit is a splendid one to beholdruffinit is a splendid one to beholdruffinit is a splendid one to beholdruffinit is a splendid one to beholdruffinit is a splendid one to behold
I had the EXACT same symptoms as you...It was my MAF. Like at light throttle the car is OK...but if you push into boost in stumbles. Here is a quick way to diagnose if it is the MAF. Just unplug the maf (takes like 2 seconds) and drive the car with just a little boost and see if it is normal. If it is normal the MAF is the culprit......when you unplug it goes to default settings.
Old Apr 11, 2007 | 10:17 PM
Joe Weinstein's Avatar
Hi all, FYI, the shop says it was the MAF, needing replacement.
I will pick the car up in time for the SCCA nationals at Atwater
and will let you all know whether there is any return of the
problem!
Joe
Old Apr 11, 2007 | 11:52 PM
sharkster's Avatar
good luck at the nationals man!
Old Apr 15, 2007 | 10:56 AM
villains_turbo's Avatar
villains_turbo is a jewel in the roughvillains_turbo is a jewel in the roughvillains_turbo is a jewel in the rough
Originally Posted by DimNSlow
Yeah, not the MAF, when I had MAF issues I just got a CEL light, no change in how the car drives.
sounds like he solved it, but the MAF can definitely cause performance/driving issues...hesitations, stumbling a bit, etc.
BTW - how much did they stick you for to replace the MAF sensor? cleaning it is a decent option too...just FYI.
Old Apr 15, 2007 | 11:03 AM
wross996TT's Avatar
I have yet to see a blown MAF brought back to life with cleaning...this is a myth. You can get MAFs on-line here:
MAF
Old Apr 15, 2007 | 11:09 AM
silvershark's Avatar
silvershark is infamous around these parts
The best place I have found for stock 996TT MAF's
www.dps-motorsports.com"
$239.00 + $9.00 shipping
You need to contact them, they don't show them on their web-site.
I hope this will save someone some $$
Old Apr 15, 2007 | 11:27 AM
MAF
perhaps it depends on how messed up it is, or possibly its just a bandaid solution, but i can say for sure that i was getting slight hesitation at partial throttle (like real partial, cruising on the highway style foot barely on the gas) that was kinda annoying and had even thrown a weird code (cant remember what it was right this sec), but i cleaned the sensor real well and all that is gone.
I assume i will have to replace it soon either way, but i had the issue on a weekend and wanted to drive, so band aid or not, it worked for me.
Old Apr 15, 2007 | 12:26 PM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
had maf probs felt just like plugs tru your maf 1st it's cheaper... i had no cells just the feel you discribed, nad not consistant.... made the mistake of checking my maf last, check it ist easy fix good luck
Old Apr 15, 2007 | 12:28 PM
cleaned mine it woorked for 6 months (very well)
Old Apr 16, 2007 | 05:45 PM
OK team, the MAF fix seems to have done it. The shop
charged me $400 for the MAF, and 2 hours to diagnose
it. The nationals were a big deal. Saturday started out
wet with a light rain, but dried by the end. AWD got me
to within 0.1 seconds of the lead after the first run, but
in the dry the DOT tire guys took over (I'm racing in a
true street tire class). Sunday was all dry, and I started
at about .005 seconds behind my main class competition,
and we swapped leads for the first two runs, and both
screwed our third runs. I beat him by more than he beat
me so I got the overall win!
Old Apr 16, 2007 | 07:48 PM
WOODTSTER's Avatar
Congrats !!!
Very nice use of car.
MK
Old Apr 16, 2007 | 07:56 PM
Thanks Woodtster! It's be a sin to own what is arguably the
best sports car in the world, ever, and not get the max out
of it. For the first four years I owned it I kept *all* records
including every receipt for all gas put in the car. I went over
them and for the first 13,000 miles overall, I averaged 8 MPG
Joe
Old Apr 16, 2007 | 07:58 PM
ard's Avatar
ard
I'll ask the question here, as it seems to have a good roster of subscribed members...
MAFs are a consumable- over time you get fouling of the sensor and a gradual degradation of the signal. Eventually the AFR is shot and a CEL is triggered when the DME can no longer adjust to keep the mixture within range (I think- this is my experience with the M5)
Is there a way to read real time fuel flow numbers via the OBDC? On the E39 M5 one can 'unlock' the display to get a real time display of instantaneous fuel delivery in L/hr. This almost direcly correlates to MAF health...
CELs with random misfire causes, stumbles at certain rpms, the 'limp home mode', or just low power without other failures are often MAF related.
We're not talking 'blown mafs', more like tired mafs...
So, my question- is there a similar function on the 996?
A
PS Nice work Joe.
PPS Steve- CRC maf cleaner works for a while, but you get oxidization that cannot be remvoed with solvents eventually
Old Apr 16, 2007 | 08:42 PM
wross996TT's Avatar
Not to my knowledge, you can hook-up several programs and get this info real time, like durametric.
