Bodywork Question
Old Apr 6, 2007 | 04:32 PM
996TT_STEVO's Avatar
996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute
Bodywork Question
I have a tiny little dent, directly above my rear wheel arch, is there anyway to access this area, I can't get access through the rear light, can i get to it through the air pod or inner wheel arch?
Roughly where the red dot is on the pic
Old Apr 6, 2007 | 04:48 PM
996twin_sc's Avatar
996twin_sc is infamous around these parts
odd....I have one as well, same side same area. Not noticeable unless the light hits it perfectly.
Old Apr 6, 2007 | 05:09 PM
This is not my car, but same side and only a tiny dent that you can notice when light hits it!
Old Apr 6, 2007 | 05:57 PM
joetwint's Avatar
joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !
There are two ways to get into that general area....one is to remove the fenderwell liner and then remove the access panel to the intercooler duct....the other is to remove the intercooler scoop below the quarter window....start at bottom with a rubber wedge and pry it out(its on clips).There is enough clearance to get between the quarter panel and intercooler duct and is the easiest way in but you may not be able to access the whole quarter panel this way.
Old Apr 6, 2007 | 07:01 PM
Thanks for that Joe
Old Apr 7, 2007 | 12:44 AM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
Take it to a Dent Doctor..They find a way to get to most dings and they usually only charge $100 per panel.
