popcorn sounds at low speeds....?????
Old Apr 12, 2007 | 08:04 AM
BMWDEMON's Avatar
BMWDEMON is a jewel in the roughBMWDEMON is a jewel in the roughBMWDEMON is a jewel in the rough
Guys,
I noticed with the radio off of course that from the front of the car at low speeds up to say 50ish that the sounds of popping (popped corn or popping corn) is audible...I looked under the hood, near the wipers, etc and can't find anything loose but whenever I take off there is that sound...anyone get this at all?
2001 996TT
Thanks all,
Mike
Old Apr 12, 2007 | 04:42 PM
BMWDEMON's Avatar
nuthin guys? man, back to teh inspection of the car...
Old Apr 12, 2007 | 08:10 PM
RiA's Avatar
RiA
RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !
Maybe a loose bit of plastic duct work???
RiA's Avatar
RiA
Mavbe a loose bit of plastic duct work???
Old Apr 13, 2007 | 06:49 AM
BMWDEMON's Avatar
I will look at it again, everything seemed pretty solid and it happens as soon as the car starts to move...you need to move pretty good for something to start sounding like pop corn so I don't think it is something loose...then again....I might get under the car next...it is driving me mad!
M
Old Apr 13, 2007 | 07:46 AM
cpu77's Avatar
cpu77 is infamous around these parts
You under boost when it happens?
Old Apr 13, 2007 | 07:50 AM
BMWDEMON's Avatar
nope, it starts as soon as the car starts rolling! It may happen at boost also but the usual car sounds deaden that sound at speed...can't try it again today since we are getting hit with rain...
Old Apr 13, 2007 | 01:36 PM
Powell's Avatar
Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !
Only thing mine does is make some like clicking popping sound from the front of the dash almost by the window. I need to take it in to the dealer because it gets really annoying if I have the radio turned down.
Old Apr 13, 2007 | 01:49 PM
cpu77's Avatar
I have a noisy sun roof
Old Apr 13, 2007 | 02:08 PM
BMWDEMON's Avatar
That is it! Let me know what happens as I am out of warranty so I can fix it! Thanks!
BLUBYOU's Avatar
BLUBYOU is infamous around these parts
Lay off the beans & beer for lunch!
Or check out your suspension pieces. I had a "popcorn" like sound in a Lexus. Turned out to be a loose bushing taking up slack when I first started rolling.
BBGT2's Avatar
BBGT2 Is a GOD !BBGT2 Is a GOD !BBGT2 Is a GOD !BBGT2 Is a GOD !BBGT2 Is a GOD !BBGT2 Is a GOD !BBGT2 Is a GOD !BBGT2 Is a GOD !BBGT2 Is a GOD !BBGT2 Is a GOD !BBGT2 Is a GOD !
Check your tires for a rock or something metal wedged in the tread.
Old Apr 13, 2007 | 03:14 PM
JoeyG's Avatar
JoeyG has much to be proud ofJoeyG has much to be proud ofJoeyG has much to be proud ofJoeyG has much to be proud ofJoeyG has much to be proud ofJoeyG has much to be proud ofJoeyG has much to be proud ofJoeyG has much to be proud ofJoeyG has much to be proud of
It's a Porsche. There is always an un-findable rattle.
Old Apr 13, 2007 | 03:59 PM
Bodybag's Avatar
Bodybag has a spectacular aura aboutBodybag has a spectacular aura about
1 - Check the torque on the front and rear wheel lugnuts. The noise you describe sounds like it could be "freting" between the wheel and lugs.
2 - Check that the bolts on the sway bar end-links are SUPER TIGHT. I had a clicking/popping sound in the front of my car that turned out to be loose end-links.
3 - Wheel Bearings? How many miles are on it? Maybe they're worn out or just need some greese.
4 - Someone put a playing card in your spokes .
Old Apr 13, 2007 | 05:51 PM
Powell's Avatar
I read a TSB on a website on 2002 for a Rattling behind the dash. I hope they cover it on my extended warranty. It really gets annoying LOL!!
