Anyone in ohio with a lightweight flywheel?
I have a Protomotive installed ATS clutch that chatters quite a bit at neutral idle. I don't believe it's the flywheel that cause the chatter, although I could be wrong. I don't mind the noise as I had a triple Tilton in my previous Supra that rattled much louder than the ATS (but only when hot). It was quiet when cold, but also had a heavy chromo flywheel.
Not sure about your hp goals, but all the triple carbon clutch plates I've seen rattle....
Good luck!
Good luck!
I have SPEC STG3 clutch and LWFW and really like the setup. The chatter though takes some getting used to. What others have said is right... in stop and go traffic it is challenging to drive. I still stall my car once in a while if I am not careful ...
Rock : As I said ill find out what setup RUF uses.. I mean they stand by drivability and performance, with as close to oem feel as possible for the most part. Marty I'm telling you the lwfw and clutch combo makes a huge diff in the turbo porsches... I feel badly you guys have a bad taste about it because of a poor combo/setup you have had previously, I LOVE the way my car feels compared to stockish throttle response!
