Best way to pass wires from front to glovebox?
Old May 7, 2007 | 07:21 PM
ArcticSilver's Avatar
ArcticSilver is a splendid one to beholdArcticSilver is a splendid one to beholdArcticSilver is a splendid one to beholdArcticSilver is a splendid one to beholdArcticSilver is a splendid one to beholdArcticSilver is a splendid one to beholdArcticSilver is a splendid one to behold
I've searched the archives, with no luck, to look for the best way to route wires from the hood area of the car into the glovebox.
Is there a easy way to do this? I had everything apart this morning but I didn't find a wire passage.
Thanks in advance for any help!
Old May 7, 2007 | 07:44 PM
PorschePhd's Avatar
On the drivers side there is an open grommet. You can pull it out and make a hole in it, pass the wires then silicone them. There are few options to go in to the passenger compartment up there. This is the easiest and less painful way. The AC system is in the way on the passenger side
Old May 7, 2007 | 08:46 PM
dtmarsh's Avatar
dtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud of
When I bot my car it had a grill mounted SR1 radar detector. The wire was routed through a 1/2" hole drilled in the wiper-rain-sensor-module that allowed routing underneath the dask. I have a pic if you want to see.
Old May 8, 2007 | 12:09 PM
If you have a photo handy, I would like to see it!
Thanks!
Old May 8, 2007 | 12:10 PM
Thank you for the info....I will check it out.
Old May 8, 2007 | 10:37 PM
dtmarsh's Avatar
Here' the pic of the hole drilled in wiper-sensor-module-cover.
Old May 8, 2007 | 10:40 PM
Thanks for your help!
Enemy
Nov 10, 2015 08:01 AM
tkebp1275
Aug 31, 2015 06:35 PM
gulf gt
Aug 27, 2015 10:27 AM
Nissan GTR
Aug 19, 2015 02:11 PM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
