Lowering the engine question
Old May 29, 2007 | 09:41 PM
MidnighTT's Avatar
MidnighTT is infamous around these parts
The plenum thread got me to thinking about lowering the engine. I dug through how-to forums on a few boards and then my pdf shop manual, but couldn't find anything useful about lowering the engine just a smidge. So...
Can someone point me to a writeup on lowering the engine enough to do intake part replacement? TIA!
Jeff
Old May 29, 2007 | 10:03 PM
dgreen78's Avatar
dgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond repute
You just need to remove the two nuts from the motor mount (18mm) from under the car and also take off the lower boost hoses to the turbos. Also, remove airfilter box. Then place the jack under the motor where the two cases come together. Make sure to put a block of wood between jack and motor. When lowering, do so slowly and watch for anything getting snagged. Pretty simple.
Old May 29, 2007 | 10:22 PM
MidnighTT's Avatar
Thanks, Don! Shoot me a PM with the cost of your turbo inlet plumbing, please. I'm only upgrading to UMW's stage 2 ZC hybrids at this point, so I may not need it now. But I will!
Jeff
Old May 29, 2007 | 10:23 PM
slant911's Avatar
slant911 is infamous around these parts
How far can you lower the engine down using this technique? Nothing needs to be disconnected? Wires, air lines, nothing???
COBB Tuning
Jan 1, 2025 09:02 AM
Jul 29, 2019 11:13 AM
The Oss
Aug 24, 2015 08:19 PM
Aug 21, 2015 06:34 AM
