Poor Handling On Curves At High Speeds
Car weighs a ton! Stock ride height. And probably out of alignment.
Suggestion: 1. Get car aligned and lowered a bit by best shop you can find (rear sensitive to bump steer issued when lowered tooo much!)...and/or 2. slow down.
I have H&R coil overs for years and have never experienced this instability although I have much different alignment than stock.
you just need a decent coilover and a decent alignment spec and you'll be fine.
Guys , will bad sway bar link cuase this ??? cuase im also expeirencing this , but i have H&R coilovers ...... sway bar links is the only thing i can think of,
and Oak, when cornerbalancing does it make that much of a difference ?
GT3 sway bar in th rear dialed all the way to the tightest setting will make a HUGE difference. I had this same problem in long sweepers and this made a huge difference. IMO corner balance won't make that big of a difference.
I dont know if anyone has eluded to this but it does also depend on how fast he was going and trying to turn at the same time. You shouldnt be trying to go around curves at 130+ miles an hour the car is going to feel like it's floating because you dont have the right downforce to take corners at that speed. There is way too much lift, this does not make the car bad at handling, but you still have to remember your driving a street car and taking highway turns at speeds way to high you are not going to be able to control the car like you will at 20 mph. At that point it becomes stupidity that needs to be resolved. (I know because I've done it, once and never again)
I agree with heavychevy, but these cars should be able to take sweeping turns at a high rate of speed. I agree 130+ is probably excessive, but 80-90 should not feel like this.
I guess what I feel is that on long sweeping turns at high speeds, the car's rear end seems to shift its weight from left to right and back a few times. Almost like it is bouncing off one side of the suspension to the other side. Hope that makes some sense.
heavy chevy ..... not true i have the same poblem and i have H&Rs , and my stock evo 9 does NO PROBLEM around the same turn same speed ...
could it be that the stock sway bar links are shot ? and there for the sway bar is loose ? im suprised no one has mentioned that yet.
Originally Posted by heavychevy
So how fast are you taking that turn anyways????????
