Fuel Pump Failed
Old Jun 22, 2007 | 08:00 PM
devious996TT's Avatar
devious996TT is infamous around these parts
Fuel Pump Failed
Hi guys,
I have a quick question, for the past week I've been feeling the car is not running as smoothly as it was and suddenly today my fuel pump went on me. Would a fuel pump failure cause any boost issues? During this week I did spike up to 1.0 bar, but usually when I floor it, I was hitting at max 0.7 bars... and today, suddenly my car just died on me.. I'm wondering, before the fuel pump actually goes, would I have any boost problems?
Old Jun 22, 2007 | 08:41 PM
wross996TT's Avatar
The fuel delivery system can effect performance (usually on the negative side...not high side), but I can't say the symptoms you speak of are related. Usually if the fuel pump or fuel line fails your car will just die (and not re-start).
Old Jun 22, 2007 | 08:58 PM
porschespeeddemon's Avatar
porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !
Dead on wross, and I know you know well that issue. MOST of the time, either the feed pressure line on the pump splits, and it just pumps fuel from the tank back into the tank, or the feed lines from the fuel pump pop off of the sending unit, essentially causing the same problem.
Old Jun 22, 2007 | 09:25 PM
robmd99's Avatar
robmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond repute
Do you smell gas?
Old Jun 22, 2007 | 09:35 PM
It may be the pick up lines .... it happened top me too and I ended up paying extra becasue they did not diagnos the problem correctly
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jun 22, 2007 | 09:38 PM
robmd99's Avatar
I told you not to use that line at the club... she made you pay more LOL
just kidding
Robert
Old Jun 22, 2007 | 10:28 PM
killerbee's Avatar
killerbee is infamous around these parts
Had two pumps fail by the internal high pressure feed line popping off. In both instances the crimped D-clip just was not tight enough and a brand new pump assembly. After the second one failed I had all the clips replaced with proper hose clamps and the problem has not reappeared in over a year.
As to runnning w/o line connected, it doesn't. No pressure no fuel to the injectors.
adnanm3
Nov 22, 2023 02:43 AM
Saint Ari
Jan 17, 2022 09:22 PM
pwdrhound
Sep 13, 2016 10:44 AM
XLR82XS
Oct 5, 2015 07:02 AM
