Difficult shift from neutral to first...
Old Apr 13, 2004 | 11:01 PM
limitup's Avatar
limitup has a spectacular aura aboutlimitup has a spectacular aura about
Originally posted by Dock (Atlanta)
Joe - I don't have any problem at all shifting into any gear, from any gear, including heel-toeing to 1st at 15-20 mph.
You downshift into 1st going 15-20mph? Isn't that bad for the car??
Old Apr 14, 2004 | 07:32 AM
Mark Singer's Avatar
Silver TT
Mark Singer is infamous around these parts
I had trouble getting the shifter out of gear and back into neutral at about 1500 to 2000 rpm...it was the ungreased splines that was causing the problem. It seems that some mechanic at Porsche is not using grease on the input shaft. The dealer pulled the tranny , greased the shaft, installed a new clutch,bearing package... It works great now!!! Perfect , smooth , like a different car. It is a 2002 TT. This is a common problem and there are many posts on it. It sounds a bit different than yours , but it might be the same shaft issue.
Old Apr 14, 2004 | 07:52 AM
BCS996TT's Avatar
BCS996TT is infamous around these parts
If you know what you are doing (match revs), so that you are not jerking the car and straining the tranny, it's no problem at all.
Old Apr 14, 2004 | 10:01 AM
Dock (Atlanta)'s Avatar
Dock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really nice
As posted just above, rev matching is the key to smoothness.
If you rev match properly, you don't even need a clutch. I don't skip the clutch in the Porsche, but I many times do all the shifting (up shifts and down shifts) in my 280Z without using the clutch.
Old Apr 14, 2004 | 04:34 PM
Garey Cooper's Avatar
Garey Cooper is infamous around these parts
My 2001.....
My '01 will shift from second into first, although it is the most balky or "coggy" (if I can use that word invention) of the shifts in the car. It helps if I let it stop in neutral for a moment and try to heel up a little revs to match the speeds a bit before attempting to slid it forward. A bit like "double-clutching" of the old days. Starting from a stop it also helps to go back to second before going forward to first in my car.
But yours sounds like more of a problem Joe, it doesn't sound "normal" to me.
Kai@ELITEMS
997 Turbo Vendor Classifieds
Nov 25, 2015 06:39 AM
Kai@ELITEMS
996 Vendor Classifieds
Nov 25, 2015 06:32 AM
Kai@ELITEMS
997 Vendor Classifieds
jyupitt1
Sep 15, 2015 04:47 PM
GSP
Sep 9, 2015 05:31 AM
