100-200 kph (62-124 mph) times for various cars and motorcycles
Old Jul 16, 2007 | 02:42 PM
vrybad's Avatar
vrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant future
Originally Posted by Jimbo
Thanks for the info. And after all is done, does it simply plug into your computer and you load the data?
You can do it that way, with a USB cable, or just pop out the sd card that all the runs are logged to and pop it into your pc card reader to access the info.
The runs are logged automatically to the card.
PBox supplies the software so that you can look at the logs after the fact.
The one thing you will need is a 12v source on your bike, like a cigarette lighter outlet, which shouldn't be too difficult to wire in.
(I apologize for cluttering up the thread!)
Old Jul 17, 2007 | 06:43 AM
C70Pete's Avatar
C70Pete is infamous around these partsC70Pete is infamous around these partsC70Pete is infamous around these partsC70Pete is infamous around these parts
Originally Posted by Jean
Good data Scott.
Luis, these tests (if from Einszweidrei), are performed from 0 kph-250 or 300kph, therefore all the times that you see here are obtained while running through as many gears as needed to go from zero to that speed, going through all the gears, like on the drag strip.
Depending on the car (brand) gearbox and tire sizes you get a different number of shifts. They are not specific 100-200kph test runs that they do in one gear.
I have accurate data for about 200 cars with their gear ratios and tire sizes, if you would like to know about the number of gears for a specific car, please ask.
Jean,
do you have gear ratios for the 335i coupe for both the 6 speed and automatic transmission as well as final drive ratio for this vehicle with the different transmissions?
thx
Pete
Old Jul 18, 2007 | 10:02 PM
Jean's Avatar
Jean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond repute
Pete, I do, I am on the move, so give me a couple of days and I will get back to you.
Old Jul 18, 2007 | 10:17 PM
C70Pete's Avatar
Jean, thx... no rush.
Old Jul 20, 2007 | 01:38 PM
Jean's Avatar
Originally Posted by C70Pete
Jean,
thx
Pete
Pete
6Speed Manual
Final ratio- max. speed limit at max. RPM
1st. 4.055 - 43mph
2nd. 2.396- 73mph
3rd. 1.58 - 111mph
4th. 1.19 - 148mph
5th. 1.0 - 178mph (Not reached, max speed 155mph)
6th. 0.872 - 205 mph (not reached)
R&P: 3.08
Automatic
1st. 4.17 - 37mph
2nd. 2.34- 66mph
3rd. 1.52 - 103mph
4th. 1.14- 138mph
5th. 0.87 - 182mph (Not reached, max speed 155 mph)
6th. 0.69 - 230 mph (not reached)
R&P: 3.46
Sorry for the hijack, maybe moderator can delete this post after Pete copies the data..
Jean
Old Jul 24, 2007 | 08:37 PM
heavychevy's Avatar
M6 is a beast for the weight, and the 996 GT2 is a beast for being out of production for so long.
Old Aug 30, 2007 | 10:06 PM
Paris_CarreraS's Avatar
Paris_CarreraS is a jewel in the roughParis_CarreraS is a jewel in the roughParis_CarreraS is a jewel in the rough
Great info!!!!!
Thanks!!!
Old Aug 31, 2007 | 07:58 AM
C70Pete's Avatar
Pete
6Speed Manual
1st. 4.055 - 43mph
2nd. 2.396- 73mph
3rd. 1.58 - 111mph
4th. 1.19 - 148mph
R&P: 3.08
Automatic
1st. 4.17 - 37mph
2nd. 2.34- 66mph
3rd. 1.52 - 103mph
4th. 1.14- 138mph
R&P: 3.46
Jean
Jean thx for the info....! looks like the auto has "faster" gear ratios than the stick!!! that is with the exception of 5th and 6th gear... from this data I would say the auto is faster than the stick froma roll on!!!
Old Sep 8, 2007 | 07:27 PM
eclou's Avatar
eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !
RC over at Rennteam just posted a 7.2 100-200 kph in a RUF stage II 997TT.
Old Sep 9, 2007 | 10:58 AM
eclou's Avatar
I finally made some runs this morning inspired by RC. 85F temps, 90% humidity. Sea level. Relatively soft launch on a 6spd manual, GIAC programming with 100 octane fuel and AWE exhaust. BMC airfilter. You can see the 100-200kph times are in the low 7 second range. Max accel was 1.12g
Old Sep 11, 2007 | 11:05 PM
Simba's Avatar
Simba has much to be proud ofSimba has much to be proud ofSimba has much to be proud ofSimba has much to be proud ofSimba has much to be proud ofSimba has much to be proud ofSimba has much to be proud ofSimba has much to be proud ofSimba has much to be proud of
Some of those numbers seem a little off. I recall my Supra doing it in about ~13 seconds bone stock, and I know the 1098 is faster than that.
Old Aug 29, 2009 | 09:33 AM
besiktas's Avatar
besiktas is infamous around these partsbesiktas is infamous around these parts
Scott, what did your car (p-car) ran 100-200 kph best?
Cheers,
Old Aug 29, 2009 | 10:17 AM
Divexxtreme's Avatar
Cheers,
Besiktas,
From 100 to 200 kph: P-car best was 4.08, and Z06 best is 5.01.
UGR's TT Gallardo did it in 2.80...LOL.
Old Aug 29, 2009 | 10:23 AM
besiktas's Avatar
Originally Posted by Divexxtreme
Besiktas,
This is with C16 right?
Do you remember what you did run with mid-boost and low-boost spec?
TT Gallardo is no joke
Old Aug 29, 2009 | 11:16 AM
Right, C16.
Best mid-boost on 100 octane was 4.48.
Best low boost on 93 octane was 4.83.
