AC Doesn't work
My car's AC stopped working and I'm wondering if anyone has a similar experience? My car only has about 35k miles and was surprised when I took my car to a outdoor wedding and the AC wouldn't work:mad:
Needless to say I wasn't very happy sweating my ass off during the wedding and on the drive homehilarious Could it be that the Freon(?) is out? Any advice, thoughts, comments would be appreciated! -paul |
Did you try the fuse? E7.
no i haven't givin that a try yet I will try that when I get home. Pardon my ignorance but is E7 the fuse for the AC, if it is will it "reset" the air conditioning unit?
Thanks Paul |
I had this issue when my ignition started to break (thanks to the dealer). My fan would turn on but the little snowflake would not appear. Even when the fan was on full blast barely any air came out.
If I turned the key slightly backwards it would come on. The car just didnt think it was turned all the way on. Weird I know. Lots of people have had ignition switches fail, you may want to try the old key trick. |
Thanks Paul |
little snow flakes come out of my vents (very cold stuff) just recharged my sys , if its low you will outside air temp only, soooooooo if your pushin hot air have it recharged and check it for leaks.............
Thanks, I did try pulling the fuse to see if it was blown, but the fuse is fine. I guess I'll have to wait for my appointment at the stealership to see if all it needs is a recharge or if I have a leak.
I am a bit disappointed that my car may already need a recharge or have a leak:( |
did you try the key thing. I didnt believe it at first but that is what the stealer showed me, and hot damn it worked.
Is it not blowing air at all? |
No I havn't had a chance to try the key trick. The fan does work and the little snow flake turns on but with no cold air.
OHHH, that is not what mine did, does sound like a recharge. Good luck...
So i got my AC fixed over the weekend. Turned out that the ground wire for the AC got disconnected somehow? Also didn't need a recharge but the stealership did it for free! lol
(Post 1291767)
YOU KIDDING!!!! hilarioushilarioushilarioushilarioushilarious |
| All times are GMT -6. The time now is 02:51 AM. |
