Octane confusion...anyone with facts?
Old Aug 21, 2007 | 11:10 AM
nerdhotrod's Avatar
nerdhotrod is infamous around these partsnerdhotrod is infamous around these parts
Originally Posted by carendt242
it's all rather easy - run the gas meant for your current program.
higher octane burns slower; if you run 110 in a stock file, you wil *lose* performance. if you run 91 in a 110 file, knock will probably get you.
as you increase octane, you can increase boost b/c the fuel burns slower and, thus, is less prone to detonation. when you increase boost, you are increasing the air inside the combustion chamber - if octane too low (and thus burns faster), the combustion more resembles a wildfire than a controlled explosion - detonation.
- chuck
We've tested many cars and in most cases you will GAIN power with race gas even on a 91/93 octane file.
When driving these cars aggressivly, the ecu will start to pull timing based on knock sensor inputs. When adding race gas to the car, the ecu will no longer pull timing because knock activity will decrease. This will more or less "advance" timing back to near the maximum amount allowed by the ecu.
For those interested....one of the factory timing tables in a 996TT ecu.
The ecu has the abilty to decrease timing 14-15s degrees based on knock sensor input
COBB Tuning
Nov 3, 2015 08:39 AM
Needsdecaf
Cayenne 958
10
Oct 12, 2015 03:05 AM
Oct 2, 2015 02:23 PM
ModBargains.com
996 Turbo Vendor Classifieds
Oct 1, 2015 11:48 AM
shifterkartracr
SoCal
Sep 24, 2015 11:05 PM
