Odessy PC680 questions
Old Sep 1, 2007 | 06:58 PM
John D's Avatar
John D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to behold
How does the PC680 hold up if you were to sit in a parking lot for 20-30 minutes listening to the radio? Any problem starting or is this type of use OK?
Old Sep 1, 2007 | 07:23 PM
its Ok John.,... I have it for 6 months now... I did it for a full 4 hours in my garage.
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Sep 1, 2007 | 08:20 PM
John D's Avatar
Thanks, Mark - Good news, will this modding ever end???
Old Sep 2, 2007 | 12:27 AM
TunaRollZ's Avatar
TunaRollZ is a glorious beacon of lightTunaRollZ is a glorious beacon of lightTunaRollZ is a glorious beacon of lightTunaRollZ is a glorious beacon of lightTunaRollZ is a glorious beacon of lightTunaRollZ is a glorious beacon of light
should be fine...unless maybe you're running a crazy 5000 watt system without a cap
Old Sep 2, 2007 | 07:42 AM
996Choy's Avatar
996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of
Would PC680 hold if you say dont drive the car for a week or so?
Still thinking whether to go 680 or 925. I usually dont drive during weekdays so i'm worried that 680 might not last for a week?
Old Sep 2, 2007 | 07:56 AM
WOODTSTER's Avatar
I just bought one and havent had it long enough to know.
I bought the 680 and the cool mounting kit, it looks very cool and saves
lots of weight.
MK
Old Sep 2, 2007 | 08:57 AM
taizen's Avatar
taizen is infamous around these parts
My car would not start after sitting for a week with the PC680. Need to always keep it on a trickle charger. It worried me that I would get stuck without juice. I switched to the Tempest battery per SallyMobile's advice. Couldn't be happier. Same weight and size as the PC680, but I don't have to keep it on a charger all the time.
Only problem with Tempest is that it does not use standard SAE terminal bolts, so you have to drill and tap larger holes in the terminal recepticles to fit the SAE terminials. Takes about 10 minutes to do.
Old Sep 2, 2007 | 09:12 AM
John D's Avatar
taizen,
Do you have a link o the tempest you are using...and the terminals, too?
Old Sep 4, 2007 | 01:42 PM
SallyMobile's Avatar
SallyMobile is a jewel in the roughSallyMobile is a jewel in the roughSallyMobile is a jewel in the rough
http://www.tempestbatteries.com/html/bab26-12.html
Those are the batteries. More info:
https://www.6speedonline.com/forums/...ad.php?t=78331
https://www.6speedonline.com/forums/...ad.php?t=66142
There's something new out that's better, but a bit costly. If you want really want to go crazy, Lithium Iron Phosphate is probably the best way to go. They're nearly as light (considering power) as Lithium Cobalt Oxide (as seen in some electric bicycle batteries), without the annoying "propensity to explode" issue.
https://s.p10.hostingprod.com/@www.v...07b71a2a3ed574
http://www.tekbattery.com/products.html
Old Sep 4, 2007 | 08:05 PM
Wheelman's Avatar
Wheelman is infamous around these parts
No, a week is pushing it with the 680. Definitely need a trickle charger unless you drive it at least 2 times a week.
Old Sep 5, 2007 | 09:42 AM
996Choy's Avatar
Thanks. Would go for 925 then
Old Sep 5, 2007 | 10:25 AM
tom kerr's Avatar
John, I have used this battery for over 2 years. I keep it on the charger every night. also while at the track. It does amazingly well but I wouldnt push it.
I also carry a battery jumper pack with me when I travel with the car.
Old Sep 5, 2007 | 05:33 PM
Divexxtreme's Avatar
I've been using a 680 for 4 years now. First on my E46 M3, and then on my TT. It lasts just over a week without being on a trickle charger, but after that it drops voltage too much. If I am gone for a week or more, I always put it on a Battery Tender. I also never listen to music without the car running.
Overall, it works awesome. You just have to remember what it's limitations are.
Old Sep 5, 2007 | 05:39 PM
davenew's Avatar
davenew is infamous around these parts
I've had a 680 in my S4 for a couple years. It will start slowly if the car sits for more than a couple weeks. I bought a porsche automatic charger from the dealer and plug it into the lighter socket whenever the car sits for awhile.
Old Sep 5, 2007 | 09:48 PM
There are definitely better choices than the PC625/680/925 these days, dollar for dollar, power for power. Technology has marched on.
