Missing, loss of power, rough idle due to bad battery??????
Old May 7, 2004 | 08:21 AM
bond's Avatar
bond is infamous around these parts
Today I noticed that my 01TT starter cranked a little slower than usual - I then ran an errand, then pushed the car up my favorite hill. Up this hill, I noticed that it was not at its usual power level. Upon returning home (up another hill), I lost power (cut out -popping noises) and barely nursed it home (idled ok). Upon starting and driving again, it quickly deteriorated to where I nursed it back to the garage, then noticed a slightly rough idle. This turned into a major miss within 15 seconds and I shut the engine off. When I first started the car, I noted that I had 13.8 volts, now with the ignition on (engine off) I checked for 12 volts, and found 11.5-11.75, which could be pulled down to 11 with lights on. I then tried to start again, and experienced the clicking starter solenoid.
Help! My questions are these:
1/ How can a bad battery affect driveability like this where it rapidly deteriorated to undrivable?? - every other car I've had would just use the 13.8 volts from the alternator.
2/ What will I have to do when I install a new battery - radio code, turn ignition on a listen for "clicks" of E-Throttle?, etc.
3/ Anyone had this failure mode with a bad battery - I have it on a charger (out of car) and it pulled over 10 amps, currently at 6-7 after a few hours.
4/ Based on my symptoms, could it be something else on top of the bad battery?
Thanks for the help
Bond
Old May 7, 2004 | 09:52 PM
NC Bob's Avatar
NC Bob is infamous around these parts
Look on Rennlist. This subject was broached several days ago and one member gave a pretty good explanation of how the battery affects performance. Good luck.
alevine
Nov 4, 2015 10:05 AM
petegtsv10
Mini Cooper
Aug 23, 2015 08:50 PM
John@SpeedTech
Aug 23, 2015 12:07 AM
silver86
Cayenne 958
Aug 21, 2015 03:08 PM
