Bolt on 20+HP for under $600??? Agency Power Intake Kit Deal
Special deal on the Agency Power Cold Air Intake Kit for your Porsche 996TT from now till September 30, 2008. NO MAF ISSUES!!!
The intake kit is high quality molded aluminum boxes powdercoated in high temperature black texture. Using a CNC machined 6061 aluminum MAF housing, the air flow stays consistent and without any check engine lights using our air flattener mesh before the sensor. Connecting the two boxes together is a 3.5 inch diameter silicone tube. Colors are available in blue, silver, red, or yellow. The air flows well with a K&N cone filter that comes preoiled and will last you almost 10,000 miles before you have to clean it. The filter is sealed in the left box to keep it cool from engine heat. As tested under street and highway conditions, the air inside the box stays approximately 5-10F degrees cooler then the engine compartment air.
The Agency Power intake achieves an impressive 32 wheel horsepower and 22 ft/lbs of torque in strong points of the RPM range. Peak numbers are 21 ft/lbs of torque and 7 wheel horsepower. This intake kit fits both the standard 996TT and the X50 package. It can be used with the factory decklid or the GT2 rear decklid.
Read our posts on the Porsche 6speed Forums HERE.
To get the Agency Power product warranty, you will need to fill out the warranty card HERE.
About Manufacturer: Agency Power
Agency Power Industries LLC was developed out of the need to provide quality, functional, and fashionable racing products. Starting from sway bar endlinks for the Subaru WRX back in 2003, Agency Power now has over 200 part numbers for cars ranging from the STI, EVO, M3, 996, TC, and more. Based out of Chandler, Arizona, Agency Power has established itself as one the core aftermarket companies for Subaru WRX STI and Mitsubishi EVO products. With new focus on the Porsche and BMW market, Agency Power is constantly developing new functional and race proven products. With dealers worldwide, the AP brand is recognized globally. Working with top distributers and tuners in the USA, AP can be found in Singapore, England, Canada, Australia, South Africa, and other parts in the EU.
Get yours for $550 shipped.
Call to order and mention Coupon Code 6speed
The aluminum cold air intakes are on CLEARANCE for $455. Order online or call me - http://www.vividracing.com/catalog/c...5431_5721.html
ECS Tuning - VW
Aug 20, 2015 03:07 PM
