996 Turbo Vendor Classifieds
Got Turbo Twists and NEED Bigger Brakes?
Old Mar 12, 2009 | 04:08 PM
vividracing's Avatar
Vivid Racing has put together the ultimate track brake kit for those 996TT drivers running OEM Turbo Twist wheels. We have taken the Porsche 996GT3 6piston caliper and combined it with the new Brembo 2 piece 350mm slotted rotors. With the addition of some Pagid Yellow RS19 brake pads and steel braided brake lines, this brake kit will give you the stopping power that your high horsepower needs.
The Brembo 2pc floating rotors use the patented McLaren hardware to offer a true center line for even pad wear and never warping your rotors. The front rotors have a larger surface area to help dissipate more heat and with the 6piston caliper, they will give you more clamping force. With 80% of your braking done up front, this is a MUST have for serious track drivers. With this setup, these rotors will out last the competition by 2x and compared to the stock rotors, will save you thousands of dollars. The calipers come directly from Porsche Motorsports in red with the white Porsche logo. We include with the kit the Pagid RS19 yellow racing pads for the ultimate in track stopping power, but with the kindest to use on the street. Our kit also includes the Agency Power front steel braided brake lines and 2 bottles of Motul Synthetic Dot 4 brake fluid. The kit is a complete bolt on with NO modifications necessary.
This is the ONLY 6piston big brake kit that will 100% clear the OEM Turbo Twist Wheels.
Kit Includes:
Porsche Motorsports GT3 6Piston Caliper
Hardware For Direct Bolt On to 996TT
Brembo 2pc Slotted 350mm Floating Rotors
Agency Power Front Steel Braided Brake Lines
2 Bottles of Motul Synthetic Brake Fluid
Pagid RS19 Yellow Brake Pads
$3599 PM, Email, or Call to order. You can also order online here - http://www.vividracing.com/catalog/p...t-p-61131.html
COBB Tuning
Jan 1, 2025 09:02 AM
2lflat4
Nov 18, 2019 05:05 PM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
ECS Tuning - VW
Aug 20, 2015 03:07 PM
Vrseis
Aug 20, 2015 07:41 AM
