996 Turbo Vendor Classifieds
ModBargains l Your #1 Source for KW Suspension l A ton of Porsche Kits in stock!!!
Old Sep 16, 2010 | 05:53 PM
ModBargains II's Avatar
ModBargains II is a splendid one to beholdModBargains II is a splendid one to beholdModBargains II is a splendid one to beholdModBargains II is a splendid one to beholdModBargains II is a splendid one to beholdModBargains II is a splendid one to beholdModBargains II is a splendid one to beholdModBargains II is a splendid one to behold
ModBargains is proud to present to the 6 Speed Online Community - KW Coilovers Variants 1,2, 3, and ClubSport for your Porsche!!!
Call in today for the ABSOLUTE LOWEST PRICE on all KW Coilovers. Please give me a call at (714) 582-3330 ext 8004 for the special price !!
About KW Coilovers
Is your Vehicle looking a little too high? Do you still feel insecure about the sharp turns you attempt around the corners? Is your current body kit not doing the job of creating that AGGRESSIVE appearance? Treat your vehicle and yourself with the best suspension system out there--KW's Coilovers! Not only does this system lower your car perfectly, but it provides HUGE performance benefits.
KW designed and manufactured every coilover to CUSTOM fit your vehicle, unlike other coilovers that may be a "special one-coilover-fits-all", guaranteeing MAXIMUM handling and performance for your vehicle. Along with handling, this system makes sure your car is given a perfectly AGGRESSIVE stance, not a vehicle that's touching the floor. Maybe you're not the one for aggressive looks and ultimate performance, but for comfort. Well, KW took that into consideration, and integrated adjustable comfort technology.
KW is known for their signature colors, individuality, quality, and security. Take a look below to read more into which KW Coilover Variant is the BEST option for you!
KW Variant 1 - $(Call for Special Pricing)
Sportive - Harmonic with KW factory pre-set up dampening
The ideal systems for customers wishing to rely on the experience of KW engineers, yet determine their own degree of lowering. In extensive driving tests our engineers have set the dampers for the best balance between sporty driving, comfort and safety.
- Optimally adjusted, sporty and comfortable dampening technology
- inox-line stainless steel technology at no extra charge
- Individually height adjustable
- German TUEV-tested lowering range
- High-quality components for long life
- Comprehensive documentation for ease of us
KW Variant 2 - $(Call for Special Pricing)
Sporty and Personalized with adjustable Rebound Dampening
The system intended for the experienced driver who requires to not only determine the individual lowering of their vehicle, but adjust the damper setting to fine tune the system to their needs. The adjustable rebound damper allows adjustment of the pitch and roll behavior of the vehicle, adapting it to one‘s own driving preferences.
- Damping technology with individually adjustable rebound
- inox-line stainless steel technology at no additional charge
- German TUEV-tested adjustment parameters
- Comprehensive documentation for ease of use
- Infinitely adjustable rebound damping
KW Variant 3 - $(Call for Special Pricing)
Race Technology for the Road with: Adjustable Compression Rebound Dampening
The new Variant 3 is state-of-the-art technology for the skilled and experienced driver. The separate and independent compression and rebound damping options allow a truly individual driving set-up. These unique systems with the 3 individually adjustable components, allows for adjustment of the compression of the damper in the low-speed range, while the high speed set-up, so decisive for driving comfort, has been preset by our engineers
- Independently adjustable damping technology -rebound and compression damping
- Individual height adjustment
- 14- level adjustable compression damping
- Unique, independently functioning damping power adjustment
What are Coilovers?
A coilover suspension basically gives you a matched lowering spring and shock absorber combination with the added benefit of adjustable ride height and spring rates through a moveable spring perch or perches. Coilovers are to your car's advantage by reducing unsprung mass, increasing suspension travel, and allowing the car to be corner balanced.
Why do KW's cost more than other Coilovers?
The answer is simple, you get what you pay for when it comes to vehicle suspension. As such a crucial component of your vehicle, suspension is definitely something you do not want to cheap out on. KW is known for their reinforced and durable suspension components. KW's coilovers have been carefully crafted and designed by studying the flaws of competitors and improving on them. In addition KW coilovers can go lower than just about any other brand and allow you to set your car to a "slammed look", "sporty look", or anywhere in between. In the unfortunate event that anything should happen to your coilovers, KW's warranty backs all their products from manufacturer's defect.
Function
  • Infinitely adjustable within German TUEV-tested adjustment parameters
  • Shortened struts for increased spring travel
  • Trapezoidal threads for simple height adjustment
  • Three different damping technologies for individual adjustment
  • Elastomer bump stops with integrated dust boot protection
  • Easy to read documentation
  • Ready to use comprehensive solutions
  • Visually perfect – safe and unique motion dynamics
Quality
  • Strut housings in inox-line stainless steel technology
  • Anodized aluminum spring collars and add-on pieces
  • High-quality, high-tensile racing springs
  • Special ventilation and sealing system
  • High-quality damping components
  • Hardened, chromium-plated piston rods
  • Special guide and sealing systems
  • Pistons with V-shaped Teflon seals – optimal sealing with minimal friction – temperature-resistant, durable damping technology
Any questions feel free to call me at (714) 582-3330 ext 8004 or e-mail me at Edward@ModBargains.com
Eddie
Old Sep 17, 2010 | 03:21 PM
Thank you for all the orders guys!
We're currently one of the best selling dealers for KW Suspension and we have the best deals available for you!
Call me today if you're ready to see how well your Porsche can handle!
- Eddie (714) 582-3330 x 8004 -
Old Sep 29, 2010 | 10:49 AM
- Alan (714) 582-3330 x 8006 -
Old Nov 2, 2010 | 05:27 PM
ModBargains's Avatar
ModBargains is infamous around these parts
*11/02/2010 - Announcement*
Hi Everyone!
Sorry for any inconveniences or unanswered E-Mails / Private Message by my former colleague Edward Chang. Eddie is no longer employed at ModBargains and has moved on to a different career path. If you guys have any questions, please contact me directly at Kevin@ModBargains.com and my 6speed online User Name: ModBargains
Thank you and looking forward to helping you guys achieve your car's goals!
Kevin Bonifacio
(714) 582-3330 ext 8009
joseph_number1
Jul 19, 2018 05:45 PM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
ECS Tuning - VW
Aug 19, 2015 02:15 PM
ECS Tuning - VW
Aug 18, 2015 01:04 PM
