Digital Torque Wrench - Holiday Special
We have gotten a lot of requests to run this special again - so we are doing so during the upcoming Holiday Season (until Dec. 25th). Our wrench makes a great gift - so don't miss out!!
The special is our Digital Torque Wrench w/ Blow Molded Case for $99 - including shipping. Just go to our website: Brown Line Metalworks, LLC | Professional Grade Digital Torque Wrench and click on the "Buy Now" button. At checkout, enter the coupon code: 6speed
You can see the torque wrench in action in the following video:
Brown Line Torque Wrench in Action
Product Specifications
Patented Double Gear Sensing System
Designed, engineered, and tested by Brown Line Metal Works, the patented* D.G.S.S. technology ensures repeatable accuracy of +/- 3.5% both clockwise & counter-clockwise
Accurate from 20 – 100% of full scale (7% accuracy from 10 – 20% of full scale)
Microprocessor Controlled
8-bit electronics ensures accurate readings and simplicity of use
Allows for both Peak and Track mode
Individually calibrates each wrench
Supplies unique serial number for each wrench
Ratchet Head
1/2" drive reversible ratchet
32-tooth gear provides an 11.25º arc while handling high torque loads
Forged from Chromium Vanadium alloy to ensure strength
Conforms to ASME B107.10 2005 standards
Range
15 – 150 ft/lbs
180 – 1,800 in/lbs
20.3 – 203 Nm
Digital Control
Large backlit digital display shows both target torque and current read-out
Intuitive button design makes operating torque wrench simple
LEDs and digital display provide visual feedback when operating wrench
Buzzer creates audible feedback when target torque is reached
Easily switch between ft/lbs, in/lbs, and Nm
Automatically powers off when not in use for 2 minutes
Low battery indicator
Handle
Soft-touch overmold provides comfortable non-slip grip
Engineered plastics ensure an impact resistant housing
The offer is valid until Dec. 25th, and is only for the lower 48 states.
What you will want to do is press the “Buy Now” button on the website. This will take you to the “Purchase Online” section. There is a pull-down menu with two options. You want to select the wrench with case option ($150 retail). Then press “Add to Cart”. This will then take you to a window where there is a space to enter your zip code as well as a coupon code. This is where you want to enter “6speed”. Then press “Update Cart” and the $99 price will appear. You can then check-out using Paypal or Google-Checkout. You can also use a credit card if you do not have a Paypal account, but you still need to press the Paypal button. Please let me know if this does not solve the problem for you.
BLMW
BLMW
PelicanParts.com
930 Turbo Vendor Classifieds
Sep 11, 2015 12:50 PM
PelicanParts.com
993 Vendor Classifieds
PelicanParts.com
993 Turbo Vendor Classifieds
Sep 11, 2015 12:49 PM
PelicanParts.com
Macan Vendor Classifieds
PelicanParts.com
Sep 11, 2015 12:48 PM
looks and works great
