996 Turbo Vendor Classifieds
USP Rear Adjustable control arms 10% off Holiday Special!!
Old Dec 20, 2011 | 04:31 PM
Chris Green@USP's Avatar
Chris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond repute
USP Motorsports Rear Adjustable Control Arms for 996 / 997
As most of you know, these cars come from the factory with negative rear camber for maximum performance handling. This is great for track use, but when driving the vehicle regularly on the street it will destroy the inside of the tires very fast. When lowering the Porsche, camber becomes very bad and additional adjustment is a must to maintain normal tire wear. To remedy this problem, USP Motorsports has developed these adjustable control arms for your Porsche 996 and 997 vehicle. These control arms are a direct replacement for your factory rear arms, and assist with adjusting camber and toe. They are a CNC machined 6061 lightweight aluminum construction. In addition to being adjustable, these control arms also offer increased strength from the replacement of the factory urethane bushing with spherical bearing heim joint ends.
These arms are also ideal when setting up a track inspired Porsche with a spring or coilover setup. You will need maximum adjustment to set camber to spec. Each spherical bearing has CNC machined billet steel fittings for a secure and safe fit. Control arms are sold in sets of 4 and fit all 996 and 997 chassis Porsche vehicles. Lifetime warranty to the original purchaser.
Features:
- 0-3 degrees camber adjustment
- 6061 CNC machined lightweight aluminum material
(Available in chromoly steel upon request)
- Spherical bearing heim joints
- 4 way 19mm hex key for ease of adjustment during alignment in middle of bar
Here are a few pics of these arms installed on a customers car at the shop:
Normal pricing: $549
Discounted price: $494.10
Click here to order
Use coupon code "usp10off" during checkout
Jul 29, 2019 11:13 AM
COBB Tuning
Nov 9, 2015 08:02 PM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
VGLNTE1
Aug 20, 2015 08:14 PM
TrackOne
Aug 20, 2015 12:56 PM
