996 Turbo Vendor Classifieds
JRZ Suspensions for Porsche 996 @ Performance Race Solutions
Old Jan 12, 2012 | 08:16 AM
PRS's Avatar
PRS
PRS is infamous around these parts
Performance Race Solutions is your place for JRZ suspensions and components. We offer complete service for this exemplary product. Their full line of products is available through us. We also offer Race-Spec alignments services and track prep.
JRZ designed the JRZ RS to give precise chassis control when driving on track and ultimate comfort for daily driving. Easy to install, the JRZ RS is available as a complete kit with mounting hardware and springs for all applications we support.
Following JRZ’s design philosophy, the JRZ RS has a large 22 mm diameter piston rod in strut applications and a 16 mm in aluminium damper applications. This means responsive chassis control at even the smallest suspension movements.
The large piston rod in combination with the high nitrogen gas pressure creates a lifting force giving great chassis control without using a high spring rate.
Our twin tube design uses a smaller diameter piston that gives a smooth feel during street driving. Working in conjunction with our blow off compression valving patterned from our racing dampers, the JRZ RS valving is the perfect marriage between daily driving and club racing.
To work with all ranges of spring and driver needs, the JRZ RS has an extra large adjustment range. With a few clicks you can turn your smooth street car into a crisp, rock solid track car in seconds.
Features
• 22mm piston rod
• Pre-set high gas pressure
• Piston developed for street and track
• Double adjustable
o 14 clicks compression
o 24 clicks rebound
• No canister • Large adjustment range
joseph_number1
Jul 19, 2018 05:45 PM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
PelicanParts.com
996 Vendor Classifieds
Aug 18, 2015 03:45 PM
PelicanParts.com
Aug 18, 2015 03:43 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 18, 2015 03:42 PM
