996 Turbo Vendor Classifieds
ar design | Ksport ProComp BBK
Old Apr 11, 2013 | 02:19 PM
AR Design's Avatar
AR Design is infamous around these parts
ProComp 8 Piston BBK
Ksport big brake kits provide the ultimate in stopping power for your vehicle. Integrating new brake technology into the design of the kits allows for a kit that highly reduces brake fade and continually cools and refreshes the brake pads surface under braking. These brake systems are designed for easy installation with minimal tools required (in most applications).
Our extreme lightweight caliper comes in differential bore configuration. It is machined from aircraft quality billet, weighs just over 5lbs. each, and has machined in protection grooves for the bridge tubes. Aluminum pistons, high temperature seals, and stainless steel brake pad wear plates are also standard on each caliper design. The opposed piston caliper design greatly improves pad wear and caliper rigidity over the OEM design. The stainless steel brake lines stop expansion under pressure.
Most applications utilize the 2-piece floating disc assembly, which reduces weight both rotating and unsprung. The floating disc also stops thermal stresses of extreme heat from warping the disc or cupping the braking surface. The unique slot design on the rotor greatly reduces braking noise and expels gas and pad debris faster than conventional slot designs. Every rotor is always heat treated and balanced before shipment for the best possible performance. Cross drilled rotors tend to run cooler than slotted and are recommended for daily driven vehicles. Slotted rotors are recommended for vehicles that will be seeing more track use than daily driving.
Fitment - 996/996tt/997/997tt
Part Numbers - Front
BKPO010-841SO (356mm Rotor) $1995.00
Part Numbers - Rear
BKPO010-433SO - 4 Piston (330mm Rotor) $1805.00
BKPO010-443SO - 4 Piston (356mm Rotor) $2138.00
BKPO010-653SO - 6 Piston (380mm Rotor) $3183.00
(Please specify Year and Model when Inquiring)
Contact us today for a great price shipped to your door!
ModBargains
991 Vendor Classifieds
Oct 13, 2015 03:57 PM
ModBargains
991 Turbo Vendor Classifieds
Oct 13, 2015 03:56 PM
ModBargains
GT3/GT2/GT Vendor Classifieds
Oct 13, 2015 03:55 PM
ModBargains
997 Turbo Vendor Classifieds
