996 Turbo Vendor Classifieds
USP Presents | SPULEN Wheel Spacers!!!
Old Apr 22, 2014 | 04:54 PM
Chris Green@USP's Avatar
Chris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond repute
USP Motorsports presents | SPULEN Wheel Spacers For Porsches!!!
SPULEN Wheel Spacers create a more aggressive wheel and tire fitment by moving your wheels and tires outwards so they fit flush with the fender—instantaneously giving your vehicle the perfect stance. SPULEN spacers allow a person to use every millimeter of fender space available and are designed for the best look and highest performance. Wheel spacers also improve the handling of your vehicle by widening the wheel track.
With SPULEN Wheel Spacers installed on your hubs, you can also run larger brakes. Spacers achieve this by providing additional clearance behind the wheel, which will allow for bigger brakes.
Made specifically for your Porsche. These spacers are CNC'D from lightweight aluminum and hard anodized for longevity and OEM appearance.
No more fighting to remove wheel spacers from your hub. All SPULEN Wheel Spacers feature relief cuts for easy removal. The 2 CNC relief cuts allow the user to simply insert a flat head screw driver between the spacer and wheel hub, removing the spacer in seconds.
Includes 2 Spacers
Note: If using with aftermarket wheels, confirm fitment before installation.
SPULEN Wheel Spacers are IN STOCK & ready to SHIP!!
CLICK HERE for 15mm Spacers!!
CLICK HERE for 7mm Spacers!!
Questions?
Email: phil@uspmotorsports.com
Phone: (888) 755-7772
or PM me!!
ID:	364204   Click image for larger version
ID:	364205   Click image for larger version
Old Jun 8, 2014 | 07:43 AM
Ursoboostd's Avatar
Ursoboostd is a name known to allUrsoboostd is a name known to allUrsoboostd is a name known to allUrsoboostd is a name known to allUrsoboostd is a name known to allUrsoboostd is a name known to all
Do these require longer bolts to do 7mm front and 15mm rear with stock turbo wheels?
Old Jun 9, 2014 | 07:58 AM
They are suggested for both the 7mm and 15mm.
PelicanParts.com
930 Turbo Vendor Classifieds
Aug 18, 2015 04:01 PM
PelicanParts.com
964
Aug 18, 2015 03:57 PM
PelicanParts.com
964 Turbo
Aug 18, 2015 03:56 PM
PelicanParts.com
Aug 18, 2015 03:51 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 18, 2015 03:42 PM
