USP Motorsports | Dont Forget Your Service Parts!!
Old May 14, 2013 | 09:14 AM
Chris Green@USP's Avatar
Chris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond repute
USP Motorsports | Porsche Service Parts
Recently we have been asked for service parts for 911 Turbos - We are happy to announce we are now carrying performance and service parts for all 911 Turbo models.
Below are some of the normal serviceable items you may need when taking care of your 911 Turbo!
Complete Ignition Service Kit Porsche 911 Turbo
Do you have a flashing check engine light or maybe your car has misfire codes? Either way, the likely culprit is a faulty coil pack or spark plug. USP has put together an ignition service kit complete with NGK spark plugs and new OEM coil packs. Solve those random misfires and hesitation problems caused by faulty coil packs.*
Coil packs are what give your vehicle the spark to make the power. If the spark is weak or nonexistent, power will decrease as your engine is misfiring or not utilizing a cylinder. To restore that lost power and eliminate the misfire, replace yours now. This service kit is a must for "chipped" or modified cars.
Kit Includes:
  • (6) OEM coil packs
  • (6) NGK BKR7E spark plugs
Applications:
  • Porsche 911 Turbo 996*
  • Porsche 911 Turbo 997
For more information on a Complete Ignition Service Kit Porsche 911 Turbo CLICK HERE
Mahle Air Filter - OEM Porsche
With MAHLE air filters, up to 99.9 percent of dust, soot and tire wear particles are filtered out. At the same time, an optimal air/fuel mixture is assured. The high particle uptake capacity ensures long service life under extreme conditions such as heat, cold or chemical contaminants. MAHLE quality air filters prevent premature wear of valves, cylinder working surfaces, piston rings, bearings and other engine components.
PUR seals made from specially developed polyurethane (PU) foam ensure continuous sealing between dirty and clean sides. These seals are resistant to aging, chemical effects and are temperature stable. Their flexibility is designed to exactly fit the geometry of the sealing area
Features:
  • OE Equivalent and a Direct fit Application.
  • Improves performance and fuel economy.
  • Metal-free filter cartridges with efficient filter media and high dust holding capacity guarantee dust efficiency of up to 99.9 percent.
  • MAHLE has meanwhile introduced new developments aimed at achieving higher efficiency and dust holding capacities.
  • Multi-layer filter materials made from cellulose, melt blown and nanofibers as well as completely synthetic non-woven materials.
  • MAHLE has integrated an activated carbon element in its air cleaner modules for reducing emissions.
Applications:
  • Porsche 911 GT2
  • Porsche 911 GT3
  • Porsche Carrera*
  • Porsche 911 Turbo
For more information on a Mahle Air Filter - OEM Porsche CLICK HERE
Mahle Fuel Filter - Porsche
MAHLE fuel filters use high-quality filter media reliably removing contaminants, protecting the engine and assures efficient operation of the vehicle. *MAHLE fuel filters are made from high-grade cellulose fibers impregnated with special resins. These materials are treated in a special production process: special pre-warming prepares the paper for the embossing of vertical ridges. Afterwards, the paper is folded according to requirements. Then the impregnation is cured to make the paper mechanically stable and to make it resistant to chemical and thermal influences.
Features:
  • OE-Equivalent and direct fit application.
  • Threaded connectors and original equipment quality mounting brackets.
  • High-efficiency filter media.
  • Pressure stable, heavy-duty housings.
  • Provides protection against fuel system wear and corrosion * * **
Applications:
  • Porsche 911 GT2
  • Porsche 911 GT3
  • Porsche Carrera 4
  • Porsche 911 Turbo
For more information on a Mahle Fuel Filter - Porsche CLICK HERE
Mahle Oil Filter - Porsche
MAHLE oil filters reliably prevent contaminants from entering the lubrication system and maintain oil quality as well as the performance and efficiency of the engine. Thanks to stable pleat geometry, cold start stability is assured. Load peaks up to 20 bar are compensated due to the high pressure resistance of the housing. A pressure relief valve guarantees the oil supply under all conditions – for viscous oil encountered during cold starts or at low temperatures, for extremely contaminated filter elements, or when the replacement intervals have been exceeded. * **
A non-return flow valve prevents the draining of the filter when the engine is switched off and ensures adequate oil supply when the engine is started. High-grade sealing materials and custom-fit connecting pieces assure reliable separation of contaminated and filtered oil.
*Features:
  • OE Equivalent and a direct fit replacement.
  • OE high quality filter media.
  • Traps 99% of harmful contaminants
  • Ideal for standard or synthetic motor oils
  • Eco Friendly design * * **
Applications:
  • Porsche
For more information on a Mahle Oil Filter - Porsche CLICK HERE
To order a Complete Ignition Service Kit Porsche 911 Turbo CLICK HERE
Questions?
Email: phil@uspmotorsports.com
Phone: (888) 755-7772
or PM me!!
Old Jun 13, 2013 | 08:02 AM
All items in stock and ready to ship.
Jul 29, 2019 11:13 AM
Chris Green@USP
997 Turbo Vendor Classifieds
Jan 28, 2016 02:22 PM
Chris Green@USP
996 Turbo Vendor Classifieds
Aug 20, 2015 11:30 AM
