:: ECS Tuning :: One Drain Plug To Rule Them All!!
Small but mighty, the Neodymium super magnet in an ECS Tuning magnetic drain plug collects wandering metallic particles and holds them captive until they can be wiped away at the next oil change. Next oil change? Install an ounce of prevention with a drain plug that catches and holds ferrous particles with an iron grip, before they can cause expensive engine damage.
Complete with drain plug sealing ring, the ECS drain plug accepts standard aluminum sealing rings for your convenience.
Interested in simple, effective, affordable engine protection? This ECS magnetic drain plug attracts and holds small ferrous metal particles that escape your oil filter, and holds on to them to prevent engine damage.
Just wipe away the particles from the magnetic drain plug tip at each oil change to remove abrasive particles that would otherwise scar close-tolerance engine parts and polished surfaces.
Click Here for information
Uses the standard Porsche sealing ring, and features an 8mm Allen head, just like your original drain plug. Order one Today for your next oil change. Also don't forget to check out all of our oil and maintenance service kits.
ECS Tuning - VW
Aug 24, 2015 01:51 PM
ECS Tuning - VW
Aug 19, 2015 02:15 PM
ECS Tuning - BMW
Aug 19, 2015 09:29 AM
