:: ECS Tuning :: Ziza License Plate LED Kit | Installs In Minutes!
Old Aug 27, 2014 | 12:48 PM
ECS Tuning - Porsche's Avatar
If you've spent any time around cars, then you know how boring and ugly the OEM yellow license plate bulbs look. They are dim and washed out, often detracting from the overall look of your car at night.
These are direct replacement bulbs that install in minutes, with no need to wire up fancy resistors or rework your factory wiring to get them functioning properly. Simply remove your plate light assembly, replace the factory incandescent bulb with our Ziza bulb, and re-install the plate light assembly.
Old Sep 26, 2014 | 09:04 AM
Simply remove your plate light assembly, replace the factory incandescent bulb with our Ziza bulb, and re-install the plate light assembly. When installing bulbs, be sure to place the end with the large heat sink pointing upwards to ensure the brightest part of the LED will be shining down on your license plate.
Click Here for more information
COBB Tuning
Jan 1, 2025 09:02 AM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
ECS Tuning - VW
Aug 20, 2015 03:07 PM
ECS Tuning - VW
Aug 19, 2015 02:15 PM
