Recommended Brake Fluid
Old Oct 2, 2007 | 06:01 PM
johnnytaboo's Avatar
johnnytaboo is infamous around these parts
Hello again,
I told you guys I'd have alot of questions. Now I'm wondering about what kind of brake fluid is recommended for my car. I just bought new pads and stainless steel lines for the car, so I'm going to have to bleed the lines when the parts get in. I've never really experimented with brake fluids, so I'm unclear as per whether or not there are "performance" brake fluids or not. This is why I direct my question to you whom are more educated on the subject.
as always, thanks in advance for any help.
John
Old Oct 2, 2007 | 10:41 PM
Redridge's Avatar
Old Oct 3, 2007 | 10:36 AM
TheSpeedDemon's Avatar
TheSpeedDemon is infamous around these parts
I just changed out my calipers, although I used the factory Dot4 fluid, but what I can recommend to you is get a PowerBleeder.
Old Oct 3, 2007 | 01:08 PM
UCrazyKid's Avatar
UCrazyKid is infamous around these partsUCrazyKid is infamous around these parts
ATE Superblue or Type 200 (Gold)
Motul
Castrol SRF
Old Oct 4, 2007 | 09:56 PM
WARDHOG's Avatar
WARDHOG is infamous around these parts
Motul
Castrol SRF
High dollar stuff
Old Oct 4, 2007 | 10:02 PM
Fabryce@GMGRacing's Avatar
Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !
Street car-
ATE Super Gold or Super Blue - Same stuff different color.
Track cars
Castrol SRF about 95.00 per liter
ELF Super Racing - F1 level stuff $150.00 per liter
The Castrol and ELf are the BEST ...
Its not cheap but if you are tracking your car its a bargain!! Consider what brake fade might cost!!
I run SRF in my GT2 on the street we also run this in our Speed GT cars.
I just started using the ELF in one of my club cars and its awesome but it is hard to get and not as accesable as the castrol.
We carry
ATE
Castrol
Elf
Old Oct 5, 2007 | 08:53 PM
damon@tirerack's Avatar
Moderator
I carry several products:
TireRack.com - Brakes - Brake Fluids
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
Old Oct 6, 2007 | 10:11 AM
MagnusB's Avatar
MagnusB is infamous around these parts
Motul RBF600 is good for track use. Not as good as SRF but way cheaper.
If you use your car for DE it should be more than sufficient.
Old Apr 23, 2008 | 09:43 AM
Pistol's Avatar
Pistol is infamous around these partsPistol is infamous around these partsPistol is infamous around these partsPistol is infamous around these parts
ATE Superblue Brake fluid is more than enough for DD, a few autox, and few track events.
Also, would suggest some SS lines, and more track oriented brake pads - but realise, more aggressive pads are much louder.
Old Apr 23, 2008 | 10:14 AM
zdr2k's Avatar
zdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud of
DD. I use blue and gold alternately when i bleed them.
jorge
Old Apr 23, 2008 | 02:57 PM
Ray S (Chicago)'s Avatar
Ray S (Chicago) has a spectacular aura aboutRay S (Chicago) has a spectacular aura aboutRay S (Chicago) has a spectacular aura about
Street car - Stock stuff is fine
mild DE car - ATE Super Blue performs well
heavy DE/Club Racer - SRF ($$, but it's good)
Old Apr 23, 2008 | 05:57 PM
joyride's Avatar
joyride has a spectacular aura aboutjoyride has a spectacular aura aboutjoyride has a spectacular aura about
GS610 is awesome stuff.
Old Apr 23, 2008 | 09:34 PM
win911's Avatar
win911 has much to be proud ofwin911 has much to be proud ofwin911 has much to be proud ofwin911 has much to be proud ofwin911 has much to be proud ofwin911 has much to be proud ofwin911 has much to be proud ofwin911 has much to be proud ofwin911 has much to be proud of
jorge
me too!
Old May 7, 2008 | 04:44 PM
NIKAS's Avatar
NIKAS is infamous around these parts
Which of these front OEM pads are best for street DD and rare weekend track use?
996-352-949-03-M73 (Pagid)
996-352-949-03-M168 (Mintex)
996-352-949-03-M3 (Textar)
Is it important that the front and rear pads are of the same compound/brand?Thanks!
Old May 18, 2008 | 06:33 PM
rwgrif's Avatar
rwgrif is a splendid one to beholdrwgrif is a splendid one to beholdrwgrif is a splendid one to beholdrwgrif is a splendid one to beholdrwgrif is a splendid one to beholdrwgrif is a splendid one to beholdrwgrif is a splendid one to behold
Anybody try the Brembo LCF 600?
I quote:
"BremboŽ LCF 600+ (DOT 4) brake fluid has an exceptionally high dry boiling point of 601F and a wet boiling point of 399F. Brembo LCF 600+ also offers up to a 10% reduction in compressibility at 350F compared to other competitors' fluids.
Brembo LCF 600+ exceeds all DOT 4 requirements and is suitable for use in all DOT3, DOT4, and DOT 5.1 brake system applications. Brembo LCF 600+ should not be used in brake systems containing magnesium parts. LCF 600+ is an ideal choice for racing or performance use - combining ultra-high dry boiling point, low compressibility, and consistent pedal feel."
That would, specification wise, be better than ATE, Castrol or Motul.
I bought it, it's in the car but I won't be to Sebring until the end of the month. Anybody know what I'm in for? If it's as good as the specs, it ought to be terrific. Oh, and it's $109 for SIX bottles ($18 and change). Here's to hoping it's as great as it sounds and I won't be reporting back about how well the HANS worked.
