Installation Help: Upper Center Console, Defroster Trim & Door Bins
Old Jul 3, 2004 | 05:06 AM
PorschExtremist's Avatar
PorschExtremist is infamous around these parts
I just purchased the final parts to complete my full carbon kit. The upper center console I have off, but cannot get the cigarette lighter off. Then how do you take off the defroster trim and door bins? Detailed instructions would be appreciated. Thank you.
Old Jul 3, 2004 | 06:43 AM
Kevin M's Avatar
Modaholic
Kevin M has a reputation beyond reputeKevin M has a reputation beyond reputeKevin M has a reputation beyond reputeKevin M has a reputation beyond reputeKevin M has a reputation beyond reputeKevin M has a reputation beyond reputeKevin M has a reputation beyond reputeKevin M has a reputation beyond reputeKevin M has a reputation beyond reputeKevin M has a reputation beyond reputeKevin M has a reputation beyond repute
The CLA is fun.. you have to get a small flat screwdriver and push in on the metal piece while you push the CLA out of the housing.. if your looking at it in the car, it comes towards you not out.
Defrosters are easy.. remove the Sun Visors, then remove paneling along the side pillars of the windows. Then the defrosters pop out, a spatula works well, snap the new ones back into place, becareful when you pull out the center piece where the alarm light is, look carefully how it pops off and on, so you don't break the platic pieces that hold it into place. Door bins .... if you don't have a pair of needle nose Vise Scripts get them! Once you lock onto the pin that holds the bins in place that pulls out then lower the other side down and pull the whole bin out. Then remove all the little screws from the backing and replace with carbon.. Thats it
Old Jul 18, 2004 | 12:23 PM
Thanks Kevin, finally completed everything today. I appreciate your instructions, took a little patience, but everything came out well at the end.
Old Jul 18, 2004 | 03:14 PM
Kevin M's Avatar
Modaholic
Your welcome.. show us the aftermath!
Old Jul 21, 2004 | 03:39 AM
Will do Kevin, just waiting for my new steering wheel and a couple of custom pieces for the interior and I will finally be done, hopefully...
COBB Tuning
Jan 1, 2025 09:02 AM
PelicanParts.com
Sep 1, 2015 02:36 PM
PelicanParts.com
Aug 20, 2015 04:01 PM
Aug 19, 2015 06:35 PM
