Boxster rear wheel, will it fit?
Old Jul 9, 2004 | 01:12 PM
newport996's Avatar
newport996 is infamous around these partsnewport996 is infamous around these parts
Will a wheel with these specs fit on my 99 C4?
19x10 40 mm offset. This is said to fit a Boxster.
Old Jul 9, 2004 | 03:11 PM
bayarea jimmy's Avatar
bayarea jimmy is infamous around these parts
double check with your Owner's Manual (in 'technical Data'), I think you'll need 65mm rim off-set for your C4.
Old Jul 9, 2004 | 03:23 PM
alter_schwede's Avatar
alter_schwede is infamous around these parts
996 "Owner's Manual" do not incl. 19" wheels, 18" are max for the OE wheels.
10" (ET) 40mm offset = stock 10" (ET) offset 65 + 25mm spacers
I'm using the TT/C4S set of wheels with 11Jx18 ET45 and they fits perfect on my C2 Cab, w/ 285/30 tires though.
so the 10Jx19 ET40 wheels will definate fit your C4, will propably match the fender perfectly!
cheers,
Tony
Old Jul 10, 2004 | 02:14 AM
Are you sure it is +25mm spacers (not -25mm)??
Old Jul 10, 2004 | 02:30 AM
newport996's Avatar
That's what I am thinking.....
Old Jul 10, 2004 | 05:38 AM
sorry, I mean plus a spacers w/ 25mm thickness
Old Jul 10, 2004 | 08:14 AM
SennaSixty8's Avatar
2 wheeled Specialist
SennaSixty8 is infamous around these parts
Exclamation
just remember that using a spacer is like taking away the positive offset of a wheel...
ie stock offset is 65mm on a 996 rear wheel
spacer is 25mm thick
you SUBTRACT the thickness of the spacer from the orig wheel's offset to obtain the final figure.....which is still 40mm from centerline....
long story short, the wheels from a BOXSTER do fit, but a 996 (w/ 65mm offset) wheel doesn't work on a 986, it hits the rear strut towers!
2lflat4
Nov 18, 2019 05:05 PM
PenguiN
Nov 12, 2015 05:24 PM
Sep 1, 2015 03:16 PM
cab83_750
Aug 19, 2015 12:37 PM
PelicanParts.com
Aug 18, 2015 03:51 PM
