Need help!! how do you guys setup for pss9?
Old May 4, 2008 | 04:15 AM
SKY213's Avatar
SKY213 is infamous around these parts
hi !! i have a question, how do you guys setup for pss9? front1-9 rear1-9
thanks!!
Old May 4, 2008 | 07:47 AM
deckman's Avatar
I don't even know how to get to my rears to adjust them!
Old May 4, 2008 | 08:15 AM
JonC4S's Avatar
JonC4S is a splendid one to beholdJonC4S is a splendid one to beholdJonC4S is a splendid one to beholdJonC4S is a splendid one to beholdJonC4S is a splendid one to beholdJonC4S is a splendid one to behold
Hi SKY213. I had the same question a while ago so I thought I would give you my responses. Lots of variation in suggestions. After all this I ended up with PSS10s anyway.
(Front/Rear). Again, these were for PSS9s, not the 10s I ended up with:
6 F 5 R
4F 5R
4F 3R
5F 3R
7 7
7 6
5 4
4 4 (not as harsh . ..)
4 3 (too stiff--went to 9 9 )
3 3
7 4
5 4
4 3
5 4 on 18s
7 6
7 6 initial good idea
7 5
5 4
Old May 4, 2008 | 09:56 AM
Redridge's Avatar
it depends on the tires as well... on pzero I use 3/3...
Old May 5, 2008 | 07:41 AM
glowone's Avatar
glowone is a splendid one to beholdglowone is a splendid one to beholdglowone is a splendid one to beholdglowone is a splendid one to beholdglowone is a splendid one to beholdglowone is a splendid one to beholdglowone is a splendid one to beholdglowone is a splendid one to behold
question
I asked the same question a month or so ago.
I understand that 9/9 is comparable to a stock setting.
Im getting mine on next week and Im going with a 7/7. Ill let you know what I think.
Im putting the stock wheels and tires back on for a starting point.
Old May 5, 2008 | 09:43 AM
erubin's Avatar
erubin is infamous around these parts
Just ordered a set of PSS10's. Did you, or are you planning to,upgrade to larger Sway bars as well?
Old May 5, 2008 | 11:52 AM
himself's Avatar
himself is a jewel in the roughhimself is a jewel in the roughhimself is a jewel in the rough
thanks!!
Where do you drive the car, street, track or both?
Personally, I have 3F/2R.
-td
Old May 5, 2008 | 01:22 PM
SKY213's Avatar
thanks for all. i use on street and track so what the best setup on street and track? thanks
Old May 5, 2008 | 01:27 PM
SKY213's Avatar
thanks. letme know, i wait for it
Old May 5, 2008 | 01:28 PM
SKY213's Avatar
6 F 5 R
4F 5R
4F 3R
5F 3R
7 7
7 6
5 4
3 3
7 4
5 4
4 3
5 4 on 18s
7 6
7 5
5 4
thanks i will try
Old May 5, 2008 | 01:49 PM
himself's Avatar
What % is track time?
What suspension are you running, and do you have GT3 control arms/camber plates/monoball upper mounts?
Also, what tires do you run on track and on the street?
-td
COBB Tuning
Mar 29, 2016 09:26 PM
MadWhip
Sep 3, 2015 02:04 PM
Lucid Moment
Aug 20, 2015 02:22 PM
