Brake wear light on.... how long do I have
Old May 16, 2008 | 10:47 AM
CaRJoE0220's Avatar
CaRJoE0220 is infamous around these partsCaRJoE0220 is infamous around these parts
Man unexpected costs SUCK haha I will have to figure out what I need. Tomorrow is the car day!!!!
Old May 16, 2008 | 11:53 AM
UCrazyKid's Avatar
UCrazyKid is infamous around these partsUCrazyKid is infamous around these parts
Originally Posted by CaRJoE0220
Well I just drove the car and the light was off again, came back on after about a half hour of driving. I am going to remove the wheels tomorrow and check the pads. Why spend all that money on new brakes if they arent done yet, just "getting worn"
Joe,
If the brake light is not on constant it is just likely that your are low on brake fluid and need to top it off. When a brake wear sensor trips, the light stays on all the time. Check you fluid level, directions should be in the owners manual, reservoir is in the trunk (front).
Andy
Old May 16, 2008 | 01:09 PM
CaRJoE0220's Avatar
Well I turned on the car today and it was still on. I think just 1 time I started it and for the first 5 minutes it wasnt on then came back
Old May 16, 2008 | 08:38 PM
JoelPirela's Avatar
JoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond repute
My dealer told me that I needed front brakes a month ago (no light) the pads have enough material but comparing them with new pads, it's nothing!
Old May 17, 2008 | 02:58 PM
CaRJoE0220's Avatar
Originally Posted by JoelPirela
$490 includes:
Set of rotors
Set of pads
2 sensors
4 caliper screws
2 sets of retainer clips/pin and safety pin
2 sets of anti squeak/damper things
Brake fluid (big can)
Questions!!
If both sensors are not worn..... do I need 2?
Why get new Caliper screws? Whats wrong with the old ones?
Why get new retaining clips/pin... just a piece of metal?
Anti squeak things.... mine don't look worn or anything why new?
I know any dealer or website will try and sell u everything but why would u need all these new parts when the old ones are just pieces of metal/bolts/rubber that aren't rusted/cracked/or stripped?
I took apart the rear and it was all good. then the front and my front left had the brake pad sensor worn through on one side.... So im doing a front brake job.
Checking/replacing the pads is ridiculously easy compared to every other car I have done. You need a hammer and screwdriver.
Old May 17, 2008 | 09:11 PM
JoelPirela's Avatar
Hi, you are correct and you won't need all the parts, it's just my OCD to have everything new and my car is a 2002 with 90K miles, so a refresh is not that crazy.
My indy changed the rotors/pads/screws/clips, etc. I could not believe how easy that was. Not specialized tools. He did one side in 30 minutes and that was while he talked to me all the time. Great guy and he charged me $100 in labor!
I will do the rears myself!
-joel
Old May 18, 2008 | 11:43 AM
CaRJoE0220's Avatar
I was always scared to work on the P-Car myself.. even doing the oil scared me. Now that I have started working on my car myself I have found that Porsche made things so simple it seems. The most specialized tool I have ever needed was the locking lug cap adapter haha
Old May 18, 2008 | 05:50 PM
rwgrif's Avatar
rwgrif is a splendid one to beholdrwgrif is a splendid one to beholdrwgrif is a splendid one to beholdrwgrif is a splendid one to beholdrwgrif is a splendid one to beholdrwgrif is a splendid one to beholdrwgrif is a splendid one to behold
I too had the intermittent brake sensor warning. It was a shorted wire but since pads were close enough and track season starting, I had my mechanic change the sensors when I went to Hawk HP Plus pads. Imagine my surprise on my first track day in this car, my sensor came back on in the first sessions. Apparently, I COOKED the sensors (and I didn't think I was braking THAT hard).
Now where's that thread on modifying the brake cooling ducts.........
COBB Tuning
Jan 1, 2025 09:02 AM
Jul 29, 2019 11:13 AM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
007AMV8
Oct 19, 2015 09:55 PM
Michael_s
Sep 11, 2015 08:03 PM
