brake noise
Old May 17, 2008 | 03:38 PM
blown996's Avatar
blown996 is infamous around these parts
brake noise
just had new gt3 brakes with pagid yellow pads put on my car. they squeel real loud at speeds below about 10-15 mph. is this normal? will the noise go away or decrease when they are broken in?
Old May 17, 2008 | 04:53 PM
GT3 Chuck's Avatar
Administrator
if you didn't bed them in properly they will squeal...try several heavy applications from 60mph to 30mph and then a few from 80mph to 40mph without locking up the brakes and that should help...if not...there are anti brake squeal shims for the GT3 that you may not have (ask your installer if he put them in as most don't)
Old May 17, 2008 | 05:54 PM
blown996's Avatar
good call. my mechanic told me that he did not put the shims in. he has them on order already. i'll try your other recommendation till the shims come in. i'll be on the track mon and tues so i'll have a chance to brake them in. guess i'll have to put up with the noise for a couple of days.
Old May 17, 2008 | 06:03 PM
GT3 Chuck's Avatar
Administrator
have safe and fun days Monday/Tuesday...the squeal won't bother you at the track
ps...you might want to bed them in good before your track days so you get the best performance
Old May 17, 2008 | 06:28 PM
blown996's Avatar
thanks, cant wait to get out there and try the new brakes out. i warped my original rotors after an autox and 2 de's.
Old May 17, 2008 | 06:50 PM
GT3 Chuck's Avatar
Administrator
if you are getting that much heat (warped rotors) you might see if the cup brake air ducts will fit to add some cooling...just make sure you chock the car after a run and don't use the emergency brake cuz that will warp the rear rotors sure...if you warp the new fronts then you need more cooling
ModBargains
Bentley Vendor Classifieds
Oct 13, 2015 03:42 PM
ModBargains
Lotus Vendor Classifieds
ModBargains
McLaren Vendor Classifieds
Oct 13, 2015 03:41 PM
ECS Tuning - VW
Sep 2, 2015 09:03 AM
