Help! Check Engine Light 0160
Old Aug 24, 2008 | 07:21 PM
VIP C4's Avatar
VIP C4 is infamous around these parts
Got 0160 from the Code reader, something about the O2 sensor circuit not responding or something. Check light came on since K&N filter is installed. Car has 58k miles. Could this be the MAF or the just the O2 sensor? Anyways I can find out?
Old Aug 24, 2008 | 07:34 PM
1999Porsche911's Avatar
1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future
Check the wiring harness on the after cat sensor for bank 2. You may have pinched one of them. If you have a scanner, look at the reading on that sensor and make sure it fluctuates up and down as you accelerate and then let off the gas.
Error would have nothing to do with the MAF.
Old Aug 24, 2008 | 07:51 PM
The Dark Knight's Avatar
The Dark Knight is infamous around these parts
Fault condition:
Interrruption of signal wire or ground wire of 1 oxegon sensor
Oxegon sensor heating not functioning
ECM Final stage Faulty
Possible causes:
Wiring harness
Oxegon sensor
DME Control Unit
The first thing to check is the function of the oxegon sensor as described above. If the voltage fluctuates between 100 mV and 800 mV oxegon sensor is okay.
HC
Old Aug 24, 2008 | 11:09 PM
VIP C4's Avatar
I reset the code, drove car with no check light for at least 10-15 mins. On local to freeway, from normal driving to punching it... Still no check light. Until i came back and car was just idling, then all of a sudden the light came back on. If it was the wiring harness, i would think that the light would come right back on after the reset, or at least under the extreme driving conditions. Maybe the sensor is just starting to give away? Will do the sensor test later. Anyone has similar experience?
Old Aug 28, 2008 | 09:25 PM
VIP C4's Avatar
ok I am about to check the sensor, which side is the Bank2? Is it the one on the driver side or passenger side?
Old Sep 9, 2008 | 06:49 PM
cturbo28's Avatar
cturbo28 is infamous around these parts
You need to drive the car through what they call a "drive cycle" before the engine light will come back on. Some scanners will say "codes ready" that means the drive cycle is complete. Most cars are around 50 to 60 miles of driving before all codes are ready.
tropicatango
Jun 8, 2025 01:00 PM
Mini George
Jul 29, 2019 12:20 PM
Mini George
Jan 18, 2016 09:16 PM
The Oss
Aug 24, 2015 08:19 PM
