for a 2002 996 NB, will this offset work?
Old Sep 9, 2008 | 06:28 PM
JoelPirela's Avatar
JoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond repute
Hi there!
I have fronts: 8" et 50 running 225's and backs: 10 et 65 with 265's (hate that!)
Now I have a chance to get fronts: 8" et 50 for 235's and backs: 11" et 63 running 295's.
Will that be possible? any rubbing or anybody running this set up?
Many thanks!
_joel
Old Sep 9, 2008 | 06:37 PM
p0rsch3's Avatar
p0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond repute
http://www.1010tires.com/WheelOffsetCalculator.asp
You can bring the rear wheels outward about 17mm safely without rubbing, up to 20mm with aggressive camber.
I had 15mm spacers on all four wheels of my 996 with the carrera lightweight wheels, lowered, 285 rears, no issues at all.
Old Sep 10, 2008 | 05:53 AM
JoelPirela's Avatar
will I need spacers? I don't want to! ; )
Thanks for the help!
joel
Old Sep 10, 2008 | 08:02 AM
p0rsch3's Avatar
you will not need spacers, they are typically an option to enhance the look of the car. some cars do need spacers for non-standard wheel applications, such as putting NB wheels on a WB car.
Old Sep 10, 2008 | 08:16 AM
ATL's Avatar
ATL
ATL has a reputation beyond reputeATL has a reputation beyond reputeATL has a reputation beyond reputeATL has a reputation beyond reputeATL has a reputation beyond reputeATL has a reputation beyond reputeATL has a reputation beyond reputeATL has a reputation beyond reputeATL has a reputation beyond reputeATL has a reputation beyond reputeATL has a reputation beyond repute
You probably won't need spacers but if you do go with them be sure to get longer lugs, a lot of people use the stock ones and it's not enough grip IMO.
Old Sep 11, 2008 | 10:55 AM
Mother's Avatar
Mother is infamous around these parts
Good catch +1
Old Sep 11, 2008 | 11:00 AM
p0rsch3's Avatar
^ Yep, you should get about 8 or 9 turns worth of threading. any less is not enough.
Call AutoMotion www.automotion.com - they carry correct longer bolts as well as the good H&R spacers. Good prices / service.
Old Sep 11, 2008 | 11:45 AM
Redridge's Avatar
rule of thumb.... if your gonna put 7mm spacer on, you need 7mm longer bolts from stock bolts... common sense right
but, yeah those offsets you mentioned will work fine...
ATL's Avatar
ATL
It makes sense when you put it that way
2lflat4
Nov 18, 2019 05:05 PM
dc3843
Aug 22, 2015 09:33 AM
PelicanParts.com
996 Vendor Classifieds
Aug 18, 2015 03:45 PM
PelicanParts.com
996 Turbo Vendor Classifieds
Aug 18, 2015 03:43 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 18, 2015 03:42 PM
