Popping sound from speakers
Old Sep 8, 2004 | 04:16 AM
trauh's Avatar
trauh is infamous around these parts
I notice an occasional popping/crackling sound coming from my speakers occasionally. Sometimes with the system in mute, other times with it on. Any thoughts about what to check?
2001 C2 cab
radio is CR220 with the dynamic/dsp option.
Old Sep 8, 2004 | 04:38 AM
Itzkirb's Avatar
Re: Popping sound from speakers
Check the Speaker
Sounds like a blown Speaker
Old Sep 8, 2004 | 07:15 AM
mffarrell's Avatar
mffarrell is infamous around these parts
I notice the same in my car, then it goes away.
Old Sep 8, 2004 | 08:29 AM
Bobby G's Avatar
Bobby G is infamous around these parts
Sounds more like an intermittant short (less likely) or a loose connect on the back of the speaker (more likely).
If you're up to it, remove the speaker, check the connects and the wiring behind it. Be sure it's not loose or getting pinched somewhere between the mount and the door jamb.
If that doesn't work, it's probably a failing speaker.
-BG
Old Sep 8, 2004 | 08:55 AM
PMac's Avatar
PMac is a splendid one to beholdPMac is a splendid one to beholdPMac is a splendid one to beholdPMac is a splendid one to beholdPMac is a splendid one to beholdPMac is a splendid one to behold
Outside chance, but it could be interference from your cell phone. If your cell phone is close to the head unit, or any of the wiring connecting head/amp/speakers, you'll get these little warbles from time to time as the phone checks in with the tower.
Old Sep 8, 2004 | 09:29 AM
john revis's Avatar
john revis is infamous around these parts
I chased the same thing before I found it was my cell phone (Nextel). I would put it on the shelf below the radio, and when it got the signal, the speakers cracked. It was less bad in the door pocket, but would still do it at times.
Old Sep 8, 2004 | 09:40 AM
PMac's Avatar
To test the cell phone hypothesis, have someone call you on your cell phone while you're in the car with the volume turned up on a quiet signal (turn on NPR if that's your taste - talk radio lets you hear it easily). About 1/2 sec before the phone rings, you'll hear the sound pretty clearly.
If you hear nothing, it's probably something else.
Old Sep 8, 2004 | 03:47 PM
Itzkirb's Avatar
The Cell Phone thing also works on home stereos
Old Sep 8, 2004 | 09:11 PM
teflon_jones's Avatar
teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !
sounds like a loose speaker wire...
Old Sep 9, 2004 | 02:53 AM
trauh's Avatar
That's it! Gotta luv this forum
I have confirmed that it is my cell phone. I do store it under by radio in the little shelf. Sure enough, move it elsewhere and all is well. Thanks to all.
Old Sep 9, 2004 | 03:18 AM
PMac's Avatar
de nada, mon frere
Paintballzen
Oct 10, 2020 12:22 PM
Rguy
Apr 12, 2020 11:11 PM
su_maverick
Sep 8, 2015 11:12 AM
Fester
Sep 8, 2015 09:35 AM
John@SpeedTech
Sep 4, 2015 07:23 AM
