Door Speaker options
Old Aug 13, 2009 | 10:42 AM
buzzm's Avatar
buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !
did you replace the dash speakers as well or just the doors ?
Old Aug 13, 2009 | 10:59 AM
nijoma's Avatar
nijoma has much to be proud ofnijoma has much to be proud ofnijoma has much to be proud ofnijoma has much to be proud ofnijoma has much to be proud ofnijoma has much to be proud ofnijoma has much to be proud ofnijoma has much to be proud ofnijoma has much to be proud of
Best place to get speakers? For those who replaced
Where did you order these from?
Old Aug 13, 2009 | 11:00 AM
buzzm's Avatar
this looks to be the cheapest for the door speakers, not sure about dash etc
http://www.woofersetc.com/p3370/13KS...-Subwoofer.htm
Old Aug 13, 2009 | 11:03 AM
asialors996's Avatar
asialors996 has a spectacular aura aboutasialors996 has a spectacular aura aboutasialors996 has a spectacular aura about
Did the Dash, Doors, and Rears....Pictures of the rear pods i made comming soon
Old Aug 13, 2009 | 11:06 AM
buzzm's Avatar
do you remember what you used for the dash speakers ? i dont mind replacing the dash ones if its a straight swap but dont want to be running extra wires and adding amps etc
nijoma's Avatar
Thanks for the input
That was a fast answer!
Old Aug 13, 2009 | 11:07 AM
buzzm's Avatar
its been a quiet day at work, been researching for most of the morning
Old Aug 13, 2009 | 11:20 AM
I can not tell you how it will sound if you keep the stock amp. I went from the stock 40w amp to a 130wpc amp. New wiring and all new speakers.
I used MTX TA7804 and 7402 Amps...
MTX TXC4.1 Dash
MTX TXC5.1 Rear
Focal 13ks Doors
Old Aug 13, 2009 | 11:29 AM
birmy's Avatar
birmy is infamous around these parts
If you expect good, clean sound quality out of a speaker then you need to add good, clean power.
Old Aug 13, 2009 | 11:41 AM
The truth!!!
Old Aug 13, 2009 | 12:48 PM
Doug996InKC's Avatar
Doug996InKC is infamous around these partsDoug996InKC is infamous around these parts
Hey asialors996, I have the hi-fi option. Do the door speaker pods need to be sealed in order to have good sound out of a set of coaxials? The current speaker pods are vented for the factory 5 1/4, correct?
Old Aug 13, 2009 | 12:55 PM
The doors hold 5.25 inch speakers...you want them to be sealed to get the bass...I would reccoment the 13ks subs in the doors and components in the dash and rear
The 13ks subs in the doors hit superhard.
Old Aug 13, 2009 | 01:25 PM
I have a pair of Audio Innovations 8" earthquakes in custom fiberglass enclosure behind the seats. Rod suggests going 3-way or 2-way in the doors and same in dash. Local shop in Kansas City is suggesting coax in doors and coax in dash (entry-level JL Audio speakers). Your thoughts? -- Hope I'm not hijacking this thread...
Old Aug 13, 2009 | 02:32 PM
i would not waste the doors on a coax or even componnents...they are meant for bass....i would suggest just a sub....if you put full range speakers down there it will pull the audio down...the car is setup so that the image is at the occupients head level...putting full range that low in my opinion would be bad
Old Aug 13, 2009 | 02:50 PM
jarrod0073's Avatar
jarrod0073 is infamous around these parts
I listened to the focal and was not impressed for the money that one has to spend. At around the same price I found the Morel HybridOvation4 to be mush clearer speakers. A little harder to find (fewer disturbers) but sound great
