Noise After Brake Pad Change????
Old Mar 29, 2009 | 03:43 PM
FrankMin's Avatar
FrankMin is infamous around these parts
Hey Guys,
I just replaced the pads w/ factory standard ones quite easily but there is now a "grinding" sound coming from the drivers side front wheel (wasnt there before). Its a constant, speed related sound that is not affected by applying the brakes. It does seem to go away when turning to the right. I havent had a chance to pull the wheel back off yet. Any suggestions????
Frank
02 Targa
05 M3 Convertible
90 E30 M3
05 BMW K1200S
95 Ducati 900SS SP
Old Mar 29, 2009 | 05:58 PM
my996's Avatar
1999 C4 Cab 6 Speed
my996 is infamous around these parts
did you grease the retaining bolt that the pad and clamps slide on? If not, the pad might be rubbing against the rotor.
Old Mar 29, 2009 | 06:03 PM
FrankMin's Avatar
thanks,
I'll try that.
Frank
02 Targa
05 M3 Convertible
90 E30 M3
05 BMW K1200S
95 Ducati 900SS SP
Old Mar 30, 2009 | 12:44 AM
s4master1's Avatar
s4master1 is infamous around these parts
back plate is bent, check behind the rotor
Originally Posted by FrankMin
Hey Guys,
Frank
02 Targa
05 M3 Convertible
90 E30 M3
05 BMW K1200S
95 Ducati 900SS SP
sees like you bent the heat plate behind the rotor, check that one first and also remember to always replace the hardware and use antiseize when replacing brakes
Old Mar 30, 2009 | 09:01 PM
gyoung's Avatar
gyoung is infamous around these parts
if that doesn't fix it, did you do any sort of bedding in? may just be the new pads?
Old Aug 19, 2014 | 10:38 PM
ait109's Avatar
ait109 has a brilliant futureait109 has a brilliant futureait109 has a brilliant futureait109 has a brilliant futureait109 has a brilliant futureait109 has a brilliant futureait109 has a brilliant futureait109 has a brilliant futureait109 has a brilliant futureait109 has a brilliant futureait109 has a brilliant future
+1 on heat plate
Same thing happened to me. I thought I was going crazy or I screwed something up during my pad change. This thread was my first hit on google but the thread below solved my problem.
https://www.6speedonline.com/forums/...ml#post4178728
2lflat4
Nov 18, 2019 05:05 PM
Jul 29, 2019 11:13 AM
rnl
Aug 26, 2015 02:36 PM
Sales@RSW
BMW //M
Aug 26, 2015 06:41 AM
