Seat belt installation assistence for 911 turbo cab
Hi Guys,
I know a lot of you like myself elected to go for a little cooler look of the red seat belts in their 911/996 cabs or turbo cabs. I recently got a pretty good deal on a full set, front and back. I need some help with the install. If there's someone out there that either has install instructions or could walk me through the process it would be greatly appreciated. I'm assuming there is a right way to do everything as far as sequence, what has to come off and what doesn't, and where the screws are located to efficiently do the job and like all of you, I want to do it right the first time. My goal is to always do what I can do as professionally as possible and from what I'm hearing the belts are something I can do myself in my garage without the hassle and expense of paying the dealer. So any help or suggestions please send them over. I believe the '02-04Carrera Cab and Turbo Carrera Cabs should be virtually identical as far as install, it's the Cab piece that makes it a different animal due to location, access, etc. I will await someone's kind assistence or if you can point me to someone or somewhere else where I can find this information I will be indebted to you.
Thank you,
Chris Payne (916) 412-9763 cpayne63@hotmail.com
Thank you,
I actually did the front seat belts over the w-end no problem. I wouldn't have even tried w/out the PDF instructions I got from Bill, because there were a couple little tips that saved a whole lot of time and potential trouble. The backs though in a convertible are a lot more complicated to change out due to the emergency rollover system removal requirement in order to get access/clearance to the rear belt tensioners. Again, it's not something I'm willing to try w/out sufficient instructions. The rear seatbelt instructions just reference "remove the emergency rollover system" but don't tell you how. I believe there is a hyperlink in the document that Bill has that breaks it down but since I just got a copy of it, I'm not able to link it, and unfortunately for me, he's out of the country. So, if anyone else has instructions or experience in removing this system, please let me know. Otherwise, I'll be awaiting Bill's return! Thanks for the suggestions and ideas.
Chris (916) 412-9763 cpayne63@hotmail.com
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 20, 2015 02:37 PM
PelicanParts.com
991 Turbo Vendor Classifieds
Aug 20, 2015 02:27 PM
911, 996, belt, ca, cab, chris, christopher, fair, installation, instructions, oaks, payne, pdf, rear, seat
