2002 C4S 3.6 Valve train noise off idle
Has anyone had valve train noise only when the engine is at operating temperature and not at idle from 1000 rpm to 1800 rpm can also hear the noise when in gear and rolling forward at 1000 rpm to 1800 rpm the noise seems to be be coming from divers side cylinder head more exhaust cam area
thanks
thanks
I used to get a lifter tick sound when I used headers. You'll sometimes get that with a leaking exhaust manifold gasket or flange gasket between your headers, cats, or mufflers.
You may want to retorque the bolts on the exhaust system as with heat cycles they will change shape and start to leak causing the valve noise.
Cheers
Aaron
Cheers
Aaron
Cheers
Aaron
Cheers
Aaron
thanks for the input
Marko
ECS Tuning - VW
Sep 8, 2015 12:54 PM
