2002 996 Oil Pressure Gauge
Old Aug 10, 2009 | 07:12 AM
zdr2k's Avatar
zdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud of
Originally Posted by skandalis447
My brother has the same issue in his C2 MY02...After 62000miles of free running oil pressure drops below 1bar at idle when the engine is hot...ten days ago it dropped below 0,5bar while oil pressure warning came up...Today i replaced sender unit...but no luck...pressure still stays below 0,5 bar at idle...Any opinions?
what oil are you using? May need to go to a heavier weight for the summer, say 15W50 (btw, that's what i use).
Odometer sitting at 104,000 milles, nothing but mobil 1.
Old Aug 10, 2009 | 11:21 AM
skandalis447's Avatar
skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !
Guys finally i solved the problem...first i replaced sender unit with new one and had the same results...then i checked oil pressure with a mechanical gauge mounted on sender unit fitting...Oil pressure was always 1,5bar when idling hot...so everything was ok internaly...finally a bad gauge was the problem...cluster needs replacement...
Old Aug 10, 2009 | 01:19 PM
zdr2k's Avatar
did you have the cluster tested?
Old Aug 10, 2009 | 02:26 PM
EB847's Avatar
EB847 is a jewel in the roughEB847 is a jewel in the roughEB847 is a jewel in the rough
+1.. i need a new cluster for the same issue (dealer needed to order from germany) luckily it is cpo fix!
2lflat4
Nov 18, 2019 05:05 PM
Jul 29, 2019 11:13 AM
Oct 6, 2015 05:20 AM
LiquidElephant
Aug 27, 2015 06:17 PM
The Oss
Aug 24, 2015 08:19 PM
