2001 Cab rear power window help
Old Jul 28, 2009 | 10:34 AM
divemaster's Avatar
divemaster is infamous around these parts
The REAR (triangular) driver's side power window has stopped working on my 911 Cabriolet. I can hear a faint grinding type noise somewhere within the mechanism that moves the window. I can also hear the power going to the mechanism, so I don't think its the micro switch. I have accessed the mechanism through the rear panel, but do not see how to pull it out to inspect it.
How do I pull this mechanism out to fix or replace it?
Any other thoughts are appreciated as well.
Old Nov 19, 2012 | 05:49 AM
cerg82's Avatar
cerg82 is infamous around these parts
Yesterday, after putting my top up, I noticed that the rear passenger side window was only half way up. I tried to raise it completely but it wouldn't go up so I tried lowering it; after it went down completely, it wouldn't come up at all.
The rest of the symptoms are those described above.
How can I check the mechanism(remove the panel) and possibly fix it. I would like to try to fix myself instead of giving my mechanic an early Christmas bonus .
Old Nov 19, 2012 | 03:26 PM
kromdom's Avatar
kromdom is infamous around these parts
failing (or busted) window regulator.
Old Nov 19, 2012 | 05:00 PM
zeeeeeee's Avatar
zeeeeeee is infamous around these parts
I had the same problem with my car, except it was the passenger side rear quarter. Needed a new window regulator. The part number was 99654301606. Cost approximately $550 for brand new part and approximately $250 labor.
Old Nov 19, 2012 | 08:43 PM
cerg82's Avatar
I checked and that's exactly the cost . I also found a NY-based company that repairs yours for $140 or sells a rebuilt one for $440 ($70 refund when you send a core), both with a 60 day warranty.
Old Nov 19, 2012 | 08:46 PM
zeeeeeee's Avatar
Check here for used parts.
http://www.ladismantler.com/
Old Nov 19, 2012 | 08:55 PM
cerg82's Avatar
Thanks. Just checked but no luck.
2lflat4
Nov 18, 2019 05:05 PM
Jul 29, 2019 11:13 AM
MurderedTurbo
Aug 28, 2015 09:06 AM
gulf gt
Aug 27, 2015 10:27 AM
JMon
Aug 21, 2015 08:20 AM
