Where is the oil sending unit?
Old Aug 7, 2009 | 09:49 AM
TraderJoe's Avatar
TraderJoe is infamous around these parts
Having trouble with my gauge indicating oil failure then popping right back up to normal. Want to check connections prior to ordering a new one but don't know where it's located. Picture or diagram would be great.
Old Aug 7, 2009 | 10:43 AM
deckman's Avatar
When facing the rear of the car looking down at the engine comaprtment, the sending unit is on the very far right side, just about as deep down and to the back of the compartment as you can see or would be able to reach is some of the stuff was moved out of the way. The unit is silverish in color, about 2.5" in diameter, and about 3" tall. It has 3 wires attached to the top of the unit. I can't get to my camera right now, but maybe you can locate based on this discription.
Old Aug 7, 2009 | 06:16 PM
kpl's Avatar
kpl
kpl is infamous around these parts
I just posted this in another thread, but here ya go:
Old Aug 7, 2009 | 07:29 PM
Dharn55's Avatar
Dharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud of
Here is a link to a DIY for replacing the sender unit on Rennlist.com. Thought it might help.
http://forums.rennlist.com/rennforum...ement-diy.html
Old Aug 9, 2009 | 12:02 PM
TraderJoe's Avatar
Thank you. I gave the wires a cleaning and now problems so far.
Old Aug 9, 2009 | 12:38 PM
Dharn55's Avatar
Good to hear that cleai=ning the wires seemed to solve the problem. that is alot easier and less expensive than replacing the unit.
cnebrask
Oct 3, 2024 08:19 PM
riverflyer
Sep 1, 2015 04:22 PM
LiquidElephant
Aug 27, 2015 06:17 PM
gulf gt
Aug 27, 2015 10:27 AM
The Oss
Aug 24, 2015 08:19 PM
