Question on Flash's for another MAF
Old Sep 10, 2009 | 07:26 AM
YoopsRacing's Avatar
YoopsRacing is infamous around these parts
Guys when AWE GIAC, FVD, EVO etc....do these Flash's do they also increase the expansion size/range for the DME? Thus allowing more range for the MAF Sensor? My dealer is telling me that because I own the EVOMS cold air intake the reason I go thru MAFSensors so often approx 1-2 every 24mos is that the DME Range is altered and the change in Airflow due to the EVOMS or any aftermkt cold air intake, eventually will kill every new Sensor over time. The OEM intake is designed for the stock DME range the aftermkt must have a flash to solve this problem. In fact they go so far to say that every new MAF installed is taxing the ECU meaning the ECU is trying to compensate for the EVOMS air and over time will give a CEL guaranteed.
This is not because of a reoiled filter - I am using the original with only 1500 miles on it.
Tired of this, what is the real answer here? Does EVOMS have a Flash that solves this for their products?
Old Sep 10, 2009 | 08:06 AM
2muchtime's Avatar
2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute
When I called and questioned the Gt700 from EVO the guy told me they go with a Hiatchi MAF so it can handle the increased air flow and work with the Flash, he said the OEM MAF will fail over time??
Old Sep 10, 2009 | 12:44 PM
interesting - i will call them also
BTW anyone including sponsers,
what is the best price these days on a 996 MAF part#
996-606-123-00
nlakind
Nov 6, 2015 10:15 AM
Sep 1, 2015 03:16 PM
ritchrwi
Aug 29, 2015 08:27 PM
Aug 20, 2015 12:17 PM
Aug 19, 2015 06:55 PM
