DIY Motor Mounts
Old Oct 16, 2009 | 08:28 AM
kvhookj's Avatar
kvhookj is infamous around these partskvhookj is infamous around these parts
DIY Motor Mounts
Does anyone have a DIY for replacing the rear motor mounts in a 03 996 c2?
Old Oct 16, 2009 | 09:02 AM
Dervish's Avatar
Dervish is infamous around these parts
I followed this install from p-car http://p-car.com/diy/motormount/ It's for a 993 but shows you the steps to follow.
A few tips from me are make sure you have a long enough socket extension as the underside nuts are tricky to reach. Also, the socket itself needs to be fairly deep as the bolt screws through the nut quite far. (I got around this by using the wheel nut socket found in the Porsche tool kit 8) ) You will have to remove the airbox and emission pump to gain access to the mounts. The instructions call for 2 people at one stage, one to hold the top nut as you tighten and torque the lower one. I got round this by having long arms and using a spanner on the top nut...
jaehoppa
Oct 22, 2015 09:17 PM
the5
Oct 14, 2015 06:46 AM
