Porsche oil leak with pictures....Help!!!
Old Jul 22, 2012 | 02:43 AM
nottoshabi's Avatar
nottoshabi is infamous around these parts
@ 1BadBlue930. How did the fix go? Was that the problem? How much did it cost.
Old Nov 20, 2012 | 10:03 AM
Szymon Kowalczyk's Avatar
Szymon Kowalczyk is infamous around these parts
have teh same issue now, anytime I take it on the highway the oil drips on the exhaust smoking the **** out of it
Old Nov 20, 2012 | 02:18 PM
jasonradner's Avatar
jasonradner is infamous around these parts
Valve Oil Leak
They do suck! I did mine in March with a leaky RMS. Amazing these things can leak from every where. Engine can be tilted...does not need to be removed. Cost me around $800.00 for both banks. Best of luck guys!
Old Nov 20, 2012 | 03:56 PM
JSavinoJr's Avatar
JSavinoJr has a spectacular aura aboutJSavinoJr has a spectacular aura aboutJSavinoJr has a spectacular aura about
Your issue seems like it's the spark plug tubes. Not a bad weekend job you can do yourself.
Old Nov 25, 2012 | 05:54 PM
Mother's Avatar
Mother is infamous around these parts
Just a thought is to clean engine first then check for the leaks.
Old Nov 15, 2019 | 07:44 AM
Edsim's Avatar
Edsim is infamous around these parts
996 needs valve cover work.
Originally Posted by ncmavro
I had a valve cover leak on my 986 which uses the same m96 block as your 996. At my indy it ran IIRC near $600 for the fix, as there was a lot of labor involved.
good day I have a 2000 Porsche 996 and the 4-5-6 head needs a valve cover what can I do, who did your work. Need help fast. Fastednice@hotmail.com
Old Nov 15, 2019 | 07:52 AM
Edsim's Avatar
2000 996 valve cover number doesn't match head
Who did your work. Major dilemma here. Bought engine to rebuild it and 4-5-6 side had valve cover damage,so I bought a valve cover now I find out the must match.
tropicatango
Jun 8, 2025 01:00 PM
joseph_number1
Jul 19, 2018 05:45 PM
BLKonBLK911C4S
NorCal
Aug 29, 2015 03:20 AM
Senatorblutarsky
Aug 28, 2015 12:44 PM
Lucid Moment
Aug 20, 2015 02:22 PM
