Anyone get a little engine rattle on cold start?
Old Jan 20, 2010 | 07:49 PM
fourempties's Avatar
fourempties has a reputation beyond reputefourempties has a reputation beyond reputefourempties has a reputation beyond reputefourempties has a reputation beyond reputefourempties has a reputation beyond reputefourempties has a reputation beyond reputefourempties has a reputation beyond reputefourempties has a reputation beyond reputefourempties has a reputation beyond reputefourempties has a reputation beyond reputefourempties has a reputation beyond repute
It's generally in the 20s when I start it up. I let the oil gauge do its countdown think before I crank, but I hear a little rattle. Common? Yes. I am new here.
Old Jan 20, 2010 | 09:44 PM
Gpjli's Avatar
Gpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud of
Hi. Here in basically the same weather I can't say I hear any rattle ( I assume you mean from the engine), just a rotation or two more from the starter. Noises are subjective things though so take this fwiw and don't lose sleep. You might expect a little extra chatter to be of no consequence. Btw, I know of no reason to do the oil gauge rundown unless you are checking the level every morning. You will get oil pressure no sooner and that is really the issue.
Old Jan 21, 2010 | 12:20 PM
Altaran's Avatar
Altaran is infamous around these parts
Is it only doing it on startup? Disappears after a while?
I had a rattle coming from the rear section. It ended up being the Cat. Try to locate if the sound is coming from the exhaust. If it is the cat and your car is under 80000 miles and less than 8 years old, it's covered under federal emissions warranty and your dealer will replace the broken Cat for free. Just had that done myself last week
Old Jan 21, 2010 | 04:51 PM
Just a half a second on start-up. Then purrs like a kitten.
Old Jan 21, 2010 | 07:20 PM
porschespeeddemon's Avatar
porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !
It is likely the chain tensioners not being fully pumped up especially with the thicker colder oil. They bleed down, and just have to be pumped up on initial startup, and as a result you get a bit of slacked chain rattle. Normal operational noise.
Old Jan 21, 2010 | 07:33 PM
Just the reply I was looking for!
Jun 10, 2017 07:45 PM
vr6tee
Aug 29, 2015 03:52 AM
magoochi
Aug 23, 2015 05:54 PM
ECS Tuning - VW
Aug 19, 2015 08:58 AM
