Help needed.Changing CV boots on a 99 c4
Hi
I have a 1999 Carrera 4. I saw last week that one of my front CV-boots was leaking. I ordered the inner and outer boots for all cv joints and I'm ready to tackle the job today.
I found out that I need a
CV-boot clamp tool
snap ring pliers
braker bar
and a 32mm socket with a braker bar.
The front one was broken, so I will start with the front ones today.
Does anybody know of a good write up for changing these boots?
I was trying to look for one, but could not find any.
Thanks beforehand
Kristian
CV-boot clamp tool
snap ring pliers
braker bar
Thanks beforehand
Kristian
Hi,
I just got the right shaft off my car. It looks like the outer CV joint is not designed for disembling, so I had to pick apart the inner one. I can slide both boots on from inside.I had to use a torch and a three prong puller to get the end piece off. I don't think that was designed for an easy replacement either. They sent me the wrong boots via mail. I checked out Napa auto parts online and it seems like they are just selling the outer ones and the rear axle inner ones. I think I have to goto the dealer for the front axle inner boots because it does not seem like anybody is selling them for a four wheel drive...
I will let you know if I can get the parts back together.
Kristian
Kristian
I just finished putting everything back together. It was not that easy. I would also get a joint braker from Harbour Freight for $17, since the ones they rent at Autozone does not work.
Also the factory bootclamps are so tight, that I could not put two of them on, so I bought some universal ones that made the job easier.
I almost gave up on changing the boots on the left side untill I found out how much the half shafts were...
Kristian
Kristian
miken168
Oct 6, 2015 09:21 AM
hsuku
Sep 27, 2015 04:39 PM
997zen
Sep 7, 2015 07:13 AM
